B18a , B18b? swapped in 95 Hatch back.......motor Mounts Requierd or Not???
The Site Saids Direct Bolt on Swap?
( http://tech.hybridgarage.com/t....html )
plus my Boy Came and he put it in without aftermarket motor mounts but the engine was leaning to the left and **** , but it still drives!? i just got a hatch and i want to do this but do i need motor motor mounts or not!
now some one Who really Knows Hit me Up ......im going to sell my Greedy Turbo For a Dohc Non Vtec......
Re: B18a , B18b? swapped in 95 Hatch back.......motor Mounts Requierd or Not??? (si Rob)
A B18A and a B18B are from different year integras. the B18A is out of a DA and the B18B is from the DC those mount are not the same.
But when you drop a 94+ integra swap into a EG its a straight drop in no after market mounts needed.
Re: B18a , B18b? swapped in 95 Hatch back.......motor Mounts Requierd or Not??? (hulkhb)
Well straight swap, but to cure the lean an Integra (94+) driver's side mount should be used.
Re: B18a , B18b? swapped in 95 Hatch back.......motor Mounts Requierd or Not??? (93 MR EJ1)
Mounting points on the engines (b18a/b18b) are the same. It just depends on the mounts you use.. Use the 94+ integra mounts for the civic chassis, like someone else mentioned already..
hondaguyexsi
09-23-2005 03:36 PM
