please check out my ignition timing alignment
Old 07-31-2004, 12:14 AM
handa's Avatar
Default please check out my ignition timing alignment
i have a timing gun w/ adjustable degrees ***.....and when i checked on my ignition timing, this is all i see:
i only see a red and a white line on the pulley...
shouldn't there be more colored marks on the pulley? does my timing look right to you? i'm confused...which colored marks on the pulley are you suppose to be looking at?
this is a b16aII. thanks.
handa is offline
Old 07-31-2004, 12:57 AM
Humble1's Avatar
Default Re: please check out my ignition timing alignment (handa)
red= at idle
white= when motor spining at 1500 rpm and timing set at specs
Humble1 is offline
Old 07-31-2004, 01:10 AM
Jesse 99EK's Avatar
The white mark is TDC. And the red mark is 16 deg before TDC.
Make sure to jump your service connector while checking your timing. (the blue plug you use to check ecu codes) And be sure your engine is idling where it's supposed to with no load.
B16A2 : 16 deg +/- 2 deg BTDC
Jesse 99EK is offline
Old 07-31-2004, 03:20 AM
Turbogixxer's Avatar
Default Re: please check out my ignition timing alignment (Jesse 99EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesse 99EK &raquo;</TD></TR><TR><TD CLASS="quote">The white mark is TDC. And the red mark is 16 deg before TDC.
B16A2 : 16 deg +/- 2 deg BTDC </TD></TR></TABLE>
You use the red mark when doing a timing belt to take the slack out of the left hand side.
Turbogixxer is offline
Old 07-31-2004, 06:36 AM
Electrician
Deemeetree's Avatar
Do you have to jump the connector while adjusting your timing? Why is this?
Deemeetree is offline
Old 07-31-2004, 07:47 AM
mct121's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Do you have to jump the connector while adjusting your timing? Why is this?</TD></TR></TABLE>
bump for a good question...
mct121 is offline
Old 07-31-2004, 08:15 AM
burningwrek's Avatar
Default Re: (mct121)
good question indeed, bump
burningwrek is offline
Old 07-31-2004, 09:48 AM
realblag's Avatar
Default Re: (Dimi)
The fuel/timing maps on the ecu alter when the spark is delivered. If you jumper the ecu, it won't be altering the spark (the gun is reading) while you are mechanically changing the actual timing.
realblag is offline
mct121's Avatar
Default Re: (Dimi)
Does not one soul understand why?
mct121 is offline
Old 07-31-2004, 10:36 AM
handa's Avatar
i jumped my service connector, turn the car on, let it warm up until the rpm reaches around 800, and did the ignition timing.
am i suppose to align the WHITE mark to the pointer?
handa is offline
Old 07-31-2004, 11:11 AM
Jago's Avatar
basicaly you jump the conector to diasable the ecu timming advance so you make sure you are seting the base timming.
Jago is offline
Old 07-31-2004, 11:29 AM
PH3593A's Avatar
Default Re: (realblag)
Does anyone know how much the service plug is? Paper clips keep popping out.
PH3593A is offline
Old 07-31-2004, 03:26 PM
Electrician
Deemeetree's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mct121 &raquo;</TD></TR><TR><TD CLASS="quote">
Does not one soul understand why?</TD></TR></TABLE>
If I understood why, I wouldn't be asking this question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realblag &raquo;</TD></TR><TR><TD CLASS="quote">The fuel/timing maps on the ecu alter when the spark is delivered. If you jumper the ecu, it won't be altering the spark (the gun is reading) while you are mechanically changing the actual timing.</TD></TR></TABLE>
I see now. Maybe that's the reason I can't get my timing within spec after I changed my timing belt. Damn, that must be the issue. My timing is off, probably by a few degrees and with 87 octane, I ping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago &raquo;</TD></TR><TR><TD CLASS="quote">basicaly you jump the conector to diasable the ecu timming advance so you make sure you are seting the base timming.</TD></TR></TABLE>
Indeed. Let me do this while I'm setting my timing to spec. I didn't know I had to do this nor have I ever seen a mechanic do this aswell.
Thanks all and sorry for hijacking the thread with my question.
Old 07-31-2004, 05:19 PM
Jesse 99EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">
am i suppose to align the WHITE mark to the pointer?</TD></TR></TABLE>
Red mark. It indicates 16 deg BTDC.
blazzer
10
01-17-2014 07:06 PM
blackbndt
10-04-2009 10:20 AM
Blackice087
03-21-2008 06:40 PM
jdurston
06-09-2004 05:30 AM
DoubleO6point9
11-10-2003 04:12 AM
Quick Reply: please check out my ignition timing alignment
  • Ask a Question
Question Title:
Description:
