A bit off topic: A 240sx brake question?
Old 07-30-2004, 11:08 AM
Rocks
Guest
Posts: n/a
Default A bit off topic: A 240sx brake question?
Well as you guys know I bought a 240sx for about 900 Bucks and I have sort of a little problem. Sometimes the brakes feel like they get stuck . I got some new pads for em and nothing. What usually causes this problem.
Old 07-30-2004, 11:19 AM
Default Re: A bit off topic: A 240sx brake question? (Rocks)
check to see if the caliper sliders are seized or need new grease. did your pads have uneven wear? is it the pedal or the actual brakeing that seems to stick?
EvoLusionX is offline
Old 07-30-2004, 11:20 AM
Rocks
Guest
Posts: n/a
Default Re: A bit off topic: A 240sx brake question? (EvoLusionX)
the pedal dosent really feel like its sticking but Ive only had the car for a couple of weeks so I wouldnt know. The pads were kinda unvenen
Old 07-30-2004, 11:41 AM
most calipers work the same way. there's the main cylinder that applies pressure to the inside pad, and two sliders that the outside pads will slide on to apply pressure to the rotor. Sometimes those boots on the sliders get messed up and the sliders grease will dry up and won't return to the "open" status as easily. Check those sliders, clean them up and apply the correct high temp break grease. that should solve your problem. Make sure your boots are secure to avoid the issue in the future.
Old 07-30-2004, 11:44 AM
Rocks
Guest
Posts: n/a
I hope I explained myself right and thanks for your help. The reason I think its my brakes its because the car slows down like you are very easily tapping the brake it wont roll for a long time with you pressing the gas it will slow down . Thanks for you help and ill try that.
Old 07-30-2004, 12:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocks &raquo;</TD></TR><TR><TD CLASS="quote">I hope I explained myself right and thanks for your help. The reason I think its my brakes its because the car slows down like you are very easily tapping the brake it wont roll for a long time with you pressing the gas it will slow down . Thanks for you help and ill try that.</TD></TR></TABLE>
hope it works
JinDIESEL is offline
Old 07-30-2004, 12:56 PM
_BEN_'s Avatar
Sliders
The grease is about 3 bucks from auto zone. And I do believe that you can get boot kits from them as well for not much.
An easy way to check is to remove tha pads and just try to push and pull and push the caliper. It should move with very little effort.
_BEN_ is offline
Nishant
06-12-2006 09:39 AM
sugarloafpkwy
14
12-04-2005 07:31 PM
thegrayghost
10-03-2004 08:02 PM
Dc2 Powered
08-06-2003 08:10 PM
CXHatchback
21
03-20-2003 07:13 AM
Quick Reply: A bit off topic: A 240sx brake question?
  • Ask a Question
Question Title:
Description:
