need help picking a motor
Old 07-31-2004, 09:49 AM
tcr03's Avatar
Default need help picking a motor
i drive a 94 del sol si. d16z6 and
its getting close to time to get the new motor. and i need some real input.
its between the
ls vtec---------$4000 installed
gsr-------------$4500 installed
i also found a shop that will do the gsr for 3800 but im not to sure of the quality of that company. i know the other shop does good work.
i can afford both but want to know which would be better. the guy at the shop says he could build a bad *** ls vtec that could put more power down than the gsr. and its cheaper.
i would like to get about 350hp out of the motor when im finaly done with it. it will be turbo charged.
so i need real input here not any bs please.
thanks in advance
matt
tcr03 is offline
Old 07-31-2004, 09:50 AM
NSTY Z33's Avatar
GSR
NSTY Z33 is offline
Old 07-31-2004, 09:57 AM
The One Upper's Avatar
Default Re: (JDMCRXDelSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRXDelSol &raquo;</TD></TR><TR><TD CLASS="quote">GSR</TD></TR></TABLE>
The One Upper is offline
Old 07-31-2004, 10:02 AM
hatchling37's Avatar
Default Re: (93 LS Si)
GSR, especially if you're not going to do it yourself. If something should go wrong with the Frankenstein (oil line coming off or loose) you're just going to have to fork over more money to get it back and running.
hatchling37 is offline
Old 07-31-2004, 10:09 AM
tcr03's Avatar
Default Re: (hatchling37)
the shop that is building it is really good. they pretty much specialize in hondas.
tcr03 is offline
Old 07-31-2004, 10:21 AM
murtnabila's Avatar
Default Re: (tcr03)
gsr for reliability ls-vtec for extra power/torque.
murtnabila is offline
Old 07-31-2004, 10:23 AM
tcr03's Avatar
Default Re: (murtnabila)
so what is the redline on an ls vtec usualy
tcr03 is offline
Old 07-31-2004, 10:46 AM
TURBOFTW's Avatar
Default Re: (tcr03)
depends on the setup
TURBOFTW is offline
Old 07-31-2004, 10:59 AM
alleyezonme's Avatar
Default Re: (h22dude)
def. go gsr if you are looking for 350 hp. why worry about the setup of the lsvtec when you can have stock reliability B4 you start builing. i just think it would be better in the long run.
alleyezonme is offline
Old 07-31-2004, 11:01 AM
why not get h22 :D
harlen is offline
Old 07-31-2004, 11:03 AM
Sliced Beard's Avatar
Default Re: (bumpincivic20)
or for the same price you can go LS and turbo that and when you have enought experience with Honda engines and knowledge you can slap a VTEC head on
I would suggest diong what I just said because you need to learn a lot before you just jump into something like that
Sliced Beard is offline
Old 07-31-2004, 11:22 AM
murtnabila's Avatar
Default Re: (dirtyd463)
I missed the 350 turbocharged. Then I would definately just stick with the gsr
jdmdomi90
03-31-2011 11:27 AM
Untouchable13
11-14-2006 03:25 PM
Flame_me
06-29-2006 09:13 AM
akoreanyoungsta
06-05-2006 07:12 PM
HONDA92HATCH
10-06-2004 07:41 PM
Quick Reply: need help picking a motor
  • Ask a Question
Question Title:
Description:
