Going to make DIY obd1 to obd1 harness for vafc or fields.
Hey guys I'm in the process of making a obd1 to obd1 harness so that you wont have to splice into your harness. When i'm done i will be posting the how to so you can make one. Oh im using the p30 ecu pinout so this will probable benefit b16 users and type r cause i know the gsr has extra wire that you need. So when im done ill let you know how it works.
Re: Going to make DIY obd1 to obd1 harness for vafc or fields. (TKBLAZER)
Apexi makes harnesses for other cars, im not sure if they make one for OBD1 Honda's.
So you made this harness in a day and it works good? Wheres pics?
Re: Going to make DIY obd1 to obd1 harness for vafc or fields. (Luserkid)
Ill post pics The heat shrink i used wasnt the best but it worked. I would do a write up but I figured that everybody on here already knew how to make one.
