best sway bar set up for the street
Old 07-31-2004, 12:49 AM
slow motion's Avatar
Default best sway bar set up for the street
Modified by slow motion at 7:51 PM 10/3/2004
slow motion is offline
Old 07-31-2004, 02:21 AM
jc836's Avatar
Default Re: best sway bar set up for the street (jdm's finest)
Although SEARCH is your friend-might I suggest that you look at ADDCO or ST for a set of streetable/autocross bars. Our '96 HB had ST's front and rear and the car was very responsive. Then again I did have stiffer springs and Konis all around. It really depends on your plan for the car. BTW: personal preference is ADDCO (available direct or from Summit)
jc836 is offline
Old 07-31-2004, 04:17 AM
heel_touge's Avatar
Default Re: best sway bar set up for the street (jc836)
comptech for the rear.
keep that subframe inforced.
heel_touge is offline
Old 07-31-2004, 04:32 AM
JDMlyfestyle's Avatar
Im looking into the SRR kit. looks very nice.
JDMlyfestyle is offline
Old 07-31-2004, 12:14 PM
Default Re: (JDMlyfestyle)
both comptech and srr only make the rear. looking for an all around set up (front & rear) or what would you use in the front with the comptech or srr in the rear?
Old 07-31-2004, 12:23 PM
piscorpio's Avatar
Suspension Techniques rear bar worked great for me (00 EX coupe, as well as 92 VX hatch). No reinforcement used, looked fine after 2.5 years of use on my coupe. I used the bar with APEXi WS coilovers also.
piscorpio is offline
Old 07-31-2004, 12:27 PM
powerfulperformance's Avatar
Default Re: best sway bar set up for the street (piscorpio)
stock civic si for the front and computech for the rear, in an ek...
powerfulperformance is offline
Old 07-31-2004, 02:11 PM
deviant1's Avatar
Default Re: best sway bar set up for the street (powerfulperformance)
if you cant afford comptech, then go with 99-00 Si front sway with Si LCAs and forks, and a ITR rear with beaks kit. good idea to upgrade to stiffer springs while you are at it.
deviant1 is offline
Old 07-31-2004, 10:07 PM
Default Re: best sway bar set up for the street (deviant1)
thanks. anymore recommendations?
Old 07-31-2004, 10:18 PM
turbotime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm’s finest &raquo;</TD></TR><TR><TD CLASS="quote">thanks. anymore recommendations?</TD></TR></TABLE>
I just bought the eibach anit-roll kit for the 92-95, its 22mm in front and 19mm in back, i should have it in like 3 days. Just bought it on ebay $150.00 brand new....(some guy bought the wrong kit cause he didnt have a stock front swaybar, which you need for the kit)
I'll post how it goes ASAP
turbotime is offline
Old 07-31-2004, 10:25 PM
buckNasty's Avatar
Default Re: best sway bar set up for the street (turbotime)
i got the comptech rear kit
stock front
tein ss
after i get new tires and an alignment
ill be loving it lol
but im looking at a ST front sway setup to upgrade the stocker
buckNasty is offline
Old 07-31-2004, 10:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">
I'll post how it goes ASAP</TD></TR></TABLE>
yeah i saw that on ebay. nice price. too bad mine's a 99, i would've outbid you
Old 07-31-2004, 10:47 PM
JDM R's Avatar
99-00 Civic Si swaybars in a hatch is perfect for the streets
JDM R is offline
Old 08-01-2004, 10:35 AM
ttt
Old 08-01-2004, 11:05 PM
so i guess that's about it...
Old 08-01-2004, 11:11 PM
rMak's Avatar
depends on how you drive. if you wanna dial out understeer, just keep the front and beef up the rear. i have an si sway on the back, and i kinda want more. its 13mm. integra rear sways are 14. ctr rear is 17, or itr i dont remember. comptechs and ss those go around 22mm. hope the numbers help you.
rMak is offline
Old 08-02-2004, 04:38 PM
piscorpio's Avatar
Default Re: best sway bar set up for the street (slowEJ8)
I believe the ST rear is about 19mm.
Mooneyes13
Suspension & Brakes
03-02-2005 11:45 AM
lowrightor
07-23-2004 09:02 AM
94ls
03-26-2003 11:58 AM
tinkfist
08-23-2002 06:52 AM
kefka
03-31-2002 08:10 AM
Quick Reply: best sway bar set up for the street
  • Ask a Question
Question Title:
Description:
