GSR Calipers
GSR Calipers
I've already done a search and found what was required to mount GSR calipers on my non-abs eg cx. What I want to know now is if it's worth it or not. What other braking upgrades should I be looking at instead? Post some opinions, I'm thinking of picking up some Monday.
its quite a bit of a braking difference over the small hatch brakes, apparently.
Another option is a larger booster/mc combo to stiffen up the pedal feel.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">
Another option is a larger booster/mc combo to stiffen up the pedal feel.</TD></TR></TABLE>
But your braking will still be ****.
I would try to find the whole knuckle, it will save you a lot of trouble,
but if you think you can do it and want to save the money, oem bigger
brakes cant hurt.
brakes cant hurt.
Re: (elwood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood »</TD></TR><TR><TD CLASS="quote">
I meant it as an option after the caliper swap
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Another option is a larger booster/mc combo to stiffen up the pedal feel.</TD></TR></TABLE>
This is going to be done anyway, hoping to pick up either teg or Si trailing arms while I'm at the junkyard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood »</TD></TR><TR><TD CLASS="quote">I would try to find the whole knuckle, it will save you a lot of trouble,
brakes cant hurt. </TD></TR></TABLE>
Yea, I'm trying to score a set of knuckles. I heard you can use VW Corrado rotors with the teg caliper set up. They're supposed to be something like 11", anyone do this?
Re: (spock_rocker)
yeah when you upgrade your cx brakes to 10.2" unit the car brakes like it's crazy. Car just stops, no brake fade nothing. Amazing improvment.
Re: (SpydiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpydiR »</TD></TR><TR><TD CLASS="quote">I heard you can use VW Corrado rotors with the teg caliper set up. They're supposed to be something like 11", anyone do this?
You minght be thinking of the prelude vtec callipers.
I have heard you can use the veedub stuff but my
rotors were just re drilled to 4x100.
Re: GSR Calipers (SpydiR)
why would u want to put gsr calipers on ur civic? are u planning on getting gsr rotors also cause it would probably be easier to get the whole steering spindle from a salvage yard.
integra calipers are larger than civic ones...all of them. The ex/si have the same size rotor as integras
(i never understood why people say "gsr calipers" since theyre all identical -ls/gs/gsr)
poormans_typer69
01-11-2008 03:24 PM
