d16z6 head+d16y7 block equals what comp ratio?
Old 07-30-2004, 09:41 PM
civictypenos's Avatar
Default d16z6 head+d16y7 block equals what comp ratio?
im using this for a boosted app.with this comp ratio,would you know what comp ratio pistons i would need for around 9:1?
civictypenos is offline
Old 07-30-2004, 09:45 PM
Risky Business
BauleyCivic's Avatar
Default Re: d16z6 head+d16y7 block equals what comp ratio? (civictypenos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos &raquo;</TD></TR><TR><TD CLASS="quote">d16z6 head+d16y7 block equals what comp ratio?
im using this for a boosted app.with this comp ratio,would you know what comp ratio pistons i would need for around 9:1?</TD></TR></TABLE>
I believe it would be less than stock, because the z6 combustion chamber is larger
BauleyCivic is offline
Old 07-30-2004, 10:05 PM
Default Re: d16z6 head+d16y7 block equals what comp ratio? (BauleyCivic)
another question.....this is for a 90 crx,we put the 97 y7 in it with no problems concerning the distributor,it bolts right in.now with the z6 head,the distributor doesnt match up.what an i do?can i get a 92-95 distributor and change out the casing for the obd0 wiring?or just modify the existing dist.?
Old 07-30-2004, 10:08 PM
Risky Business
http://www.knology.net/~jediklc/D.htm
After checking here, it seems the CC of the z6 and y7 heads are the same, so compression should stay the same.
About the distributor, this is why I always advise against using a z6 head in an OBD-2 car. No OBD2 dizzy will directly bolt onto a z6 head. You can either modify the distributor mounting holes or you can swap the guts, and I am not experienced in either.
Old 07-30-2004, 10:10 PM
its actually for a 90 crx,the 90 dist fit perfectly in to the 97 head,go figure.but now with the z6 head,i dunno what route to take yet??lol.
Old 07-30-2004, 10:12 PM
thats a sweet calculator,thanx.
Old 07-30-2004, 10:17 PM
Risky Business
A6/B7/Y7/Y8 all have the same dizzy mounting position, whereas Z6 is different...
Old 07-30-2004, 10:22 PM
i guess ill be notching it out,dont guess it will hurt much,lol.
arkomandos
09-17-2011 04:14 PM
spens 91 Ef
02-21-2009 02:56 PM
94ex-vtec
07-06-2006 05:01 AM
yz125rider21
01-11-2006 09:39 AM
civictypenos
07-30-2004 09:42 PM
Quick Reply: d16z6 head+d16y7 block equals what comp ratio?
  • Ask a Question
Question Title:
Description:
