Master cylinder is bad
Old 07-29-2004, 07:23 PM
Jaydeep's Avatar
Default Master cylinder is bad
I got 00 civic EX with 35000 miles. My brake are bad It is taking long time to stop. So I went to local mechanic. He told me master cylinder is bad. How this is possible.
Can you guys tell me what master cylinder do? Is it just for brake?
Old 07-29-2004, 07:27 PM
EGh22aEG's Avatar
Default Re: Master cylinder is bad (Jaydeep)
there is a brake and clutch master cylinder they are located at the top right of the engine bay. they are resivours(sp) that hold brake fluid its like around $130 i think to replace do it yourself its easy. dont forget to bleed them
Old 07-29-2004, 07:29 PM
Jaydeep's Avatar
Default Re: Master cylinder is bad (EGh22aEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGh22aEG &raquo;</TD></TR><TR><TD CLASS="quote">there is a brake and clutch master cylinder they are located at the top right of the engine bay. they are resivours(sp) that hold brake fluid its like around $130 i think to replace do it yourself its easy. dont forget to bleed them</TD></TR></TABLE>
Does any one have picture
Old 07-29-2004, 08:00 PM
3 G's's Avatar
See that silver thing with the reservoir attached to the black thing (Brake Booster) that says "95 AI" on it? That's your Brake Master Cylinder
Old 07-29-2004, 08:07 PM
Quad-Damag's Avatar
Default Re: Master cylinder is bad (3 G's)
dude, i got a full 00 si brake and master, everything u need yo
how much u want shipped for it??
upgrade to something a bit bigger then ur ex
00 Honda Civic Si FULL Brake Booster, and Bake Cyl and Brake Master *MINT*
Old 07-29-2004, 08:13 PM
ewaugh's Avatar
I just put a rebuilt one in mine. It's pretty easy to do, put a rag under your master cylinder and be careful not to get brake fluid on your paint beause it will eat right though it. Take a syringe and suck the fluid out of the resiovur, then unbolt your brake lines (use a line wrech so you don't strip them). Then all you have to do is unbolt the master cylinder from the booster (the black thing) and put the new one back in. The brake lines use a real low torque so don't wrench on them real hard when you put them back on (important). refill your resivor and bleed your brakes. It took me about 30 minutes to do, bleeding took about an hour though. If you don't know how to bleed just ask
Old 07-29-2004, 08:16 PM
ABK
ABK's Avatar
you milages seems a little low for the master cylinder to go out. You should start with bleeding your system. I think you mechanic is giving you ****.
Old 07-29-2004, 08:37 PM
SolObsession's Avatar
Default Re: Master cylinder is bad (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">you milages seems a little low for the master cylinder to go out. You should start with bleeding your system. I think you mechanic is giving you ****.</TD></TR></TABLE>
I would def. bleed the brakes first. Also, check the amount of material left on your pads and the condition of the rotors. Always look at the small stuff before replacing the big stuff.
Old 07-29-2004, 08:40 PM
cxSHOE's Avatar
bleed your entire system first buy two of the large containers and dont worry about the fluid. i had the same problem when i upgraded and i had air in the line and it took about 1 minute of draining the drivers side rear line to get the air out. like i said get two bottles and flush it out good...it will save you time and $
Old 07-29-2004, 08:42 PM
sheepey's Avatar
i work at autozone i can get u a BRAND NEW One let me know
Old 07-30-2004, 10:47 AM
Jaydeep's Avatar
Default Re: Master cylinder is bad (SolObsession)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SolObsession &raquo;</TD></TR><TR><TD CLASS="quote">
I would def. bleed the brakes first. Also, check the amount of material left on your pads and the condition of the rotors. Always look at the small stuff before replacing the big stuff.</TD></TR></TABLE>
I bleed the brakes already. I also check brake pads. Everything is good. Is there anything else I should check.
Do you guys think it is master cylinder. What happens if your master cylinder is bad?
Old 07-30-2004, 11:02 AM
ABK
ABK's Avatar
you could check the brake booster, valve (the one that's on the vacume line) if it's bad it will make your brakes go out from time to time.
Old 07-30-2004, 11:23 AM
Db1 Supreme's Avatar
this might help, https://honda-tech.com/zerothread?id=364783
Old 07-30-2004, 11:28 AM
ABK
ABK's Avatar
Default Re: Master cylinder is bad (QuickSilver[Eh2])
I don't think that it work on EKs but whatever. He is already running 15/16 master cylider, which is the same as part number as 99-00 SI so the only upgrade is a ctr or itr 1 inch.
Old 07-30-2004, 12:38 PM
slamedturtle's Avatar
also check to see if you are getting pressure where the brake line connects to the caliper. could have some restriction some where. easy to check if your going to end up bleeding the brakes again.
mattmw88
03-31-2008 06:08 PM
ILcrxsi1
05-28-2006 01:27 PM
Supra
07-10-2005 05:46 PM
sinister2c
07-01-2004 10:23 PM
KenTegra
04-07-2002 01:57 AM
Quick Reply: Master cylinder is bad
