Broke a chunk off my tranny.
This is my GSR tranny. Happened at the track. How bad is this? Can this tranny see the track again. Doesnt seem to be leaking :fingers crossed:
Re: Broke a chunk off my tranny. (Andres-eh2)
damn it looks pretty chipped off!
you might be able to drive it around, but definitely not on the track just to be on the safe side. weld it back on?
Re: Broke a chunk off my tranny. (handa)
you can take it off and take it to machince shop or weld shop or whatever. and have them weld the hole shut, drilled and retapped. But it has to be a good welder.
well that is where the tranny mounts to the block,
its not going to leak because there is nothing in there to leak out.
theres just the clutch in there and clutch fork.
have to wonder how the ****??
how about ya tell us meeyybe?? hehe
Re: (Tad)
I think it was overtoqued, prolly with an impact or something or other bolts were too loose and after alot of launches it finally decided to break.
Re: (Tad)
thats the rear mount right??? my buddy did that to his tranny also...
did u happpen to have the other tranny mount??
my buddy shifted so hard... and BLAM.... took a chunk...
it all happend at the track. first the motor shifted so much that the linkage slipped out from the bushing
( https://honda-tech.com/zerothread?id=941664 ) then i look today and i see that **** cracked. i did here the bolt go flying btw. i wanna look for the piece maybe it went with the bolt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 »</TD></TR><TR><TD CLASS="quote">This is my GSR tranny. Happened at the track. How bad is this? Can this tranny see the track again. Doesnt seem to be leaking :fingers crossed:
</TD></TR></TABLE>dude i had the same thing happen to a swap i put in for a friend....GSR torque rules!!!!!!!!!!!!!!!!!!
Re: Broke a chunk off my tranny. (Madspeed)
yeah I would check for the damage on the block too, and I would get the tranny welded and retapped asap because you could break everything else on it. You could also look for GSR tranny bellhousing, I don't know if all b series belhousings are the same.
Re: (Andres-eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 »</TD></TR><TR><TD CLASS="quote">you mean LS torque. Thats what i got. How does it drive with just one bolt on the side btw?</TD></TR></TABLE>
damn dude we did it with a GSR..... still a daily driven car with the bolt missing driven HARD and no trouble yet.....but Honda put that bolt there for a reason.
Re: (Madspeed)
well I'm not sure, I know that bolt goes thru either mount to the tranny or thru the block to tranny or maybe thru both. Well the other side of bolt had to come out somewhere so I would check fo it.
Here is mine, YOU CANT repair it, you must get a b-series bellhousing casing, than transfer all your gears to that casing and reseal it. I had a machine shop do mine.
Mine broke, because the bolts were stripped, so they werent never really tighten down, than my rear mount broke.
good luck man, i feel for you
Re: (the_0ne)
oh yeah your rear mount might be shot as well as your L mounts. I think it caused your shifter bushing to slip out along with braking your tranny.
Risky Business
Re: (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">arent there 2 bolts for the rear bracket??</TD></TR></TABLE>
Theres 3...two for the trans, one for the motor
Dude that bellhousing is done, my slave cylinder bolt hole was cracked so I jbwelded a stud in there and it works fine, but that is not something you want to jb weld. Get a new bellhousing or new trans altogether if you wanna keep racing...
Re: (hatchi)
mine was WORSE and i fixed it , after constant thrashin at 12psi my tranny went out (motor went out soon after ). All 3 bolts were stripped and the back 2 chucks snapped off first it was a crack then eventually a chunk came out i paid 100 bucks to get this tranny and another welded. all i had to do was shave it down flat tap it and i was back on the road.
