Anyone ever POPPED a Goodridge S.S. Brakeline??????????
Old 07-30-2004, 08:52 PM
impound's Avatar
Default Anyone ever POPPED a Goodridge S.S. Brakeline??????????
i just did ....anyone know if there is a warranty ???
I Made it home with this:
Heres My Hole:
Modified by impound at 2:24 AM 8/2/2004
impound is offline
Old 07-30-2004, 09:19 PM
Draggin99Si's Avatar
Default Re: Anyone ever POPPED a Goodridge S.S. Brakeline?????????? (impound)
Nope, never have.
Goodridge's customer service kicks *** though. I needed a new banjo bolt, and they sent me one free of charge. So just give them a call.
Lets see those pics.
Draggin99Si is offline
Old 07-30-2004, 09:22 PM
impound's Avatar
Default Re: Anyone ever POPPED a Goodridge S.S. Brakeline?????????? (Draggin99Si)
i gotta get the wheel back off...i put some duct tape and 10 zip ties around it so i could make it home...forgot i had my camera with me til i was leaving...
impound is offline
Old 07-30-2004, 09:26 PM
How badly was it leaking fluid?
Old 07-30-2004, 09:34 PM
pdiggitydogg's Avatar
dont they have a "guaranteed forever" policy?
pdiggitydogg is offline
Old 07-31-2004, 06:52 AM
impound's Avatar
Default Re: (pdiggitydogg)
it was squirting like a foot
impound is offline
Old 07-31-2004, 07:24 AM
miahmouse's Avatar
Default Re: (impound)
wait, so you drove your car home... without brakes...?
edit: and leaking brake fluid onto roads which people will then get on their paint?
miahmouse is offline
Old 07-31-2004, 01:47 PM
impound's Avatar
Default Re: (miahmouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse &raquo;</TD></TR><TR><TD CLASS="quote">wait, so you drove your car home... without brakes...?
edit: and leaking brake fluid onto roads which people will then get on their paint?</TD></TR></TABLE>
yes...10 zip ties and duct tape.....e-brake and downshifting....actually didnt use the brakes once
impound is offline
Old 07-31-2004, 02:33 PM
Filliam H. Muffman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by impound &raquo;</TD></TR><TR><TD CLASS="quote">
yes...10 zip ties and duct tape.....e-brake and downshifting....actually didnt use the brakes once</TD></TR></TABLE>
my brakes just went out on me
Filliam H. Muffman is offline
Old 07-31-2004, 02:41 PM
DeadEG's Avatar
Default Re: (JUN EK9)
That's why most manufacturers have gone to outter protective shielding on the brake lines to prevent dirt from entering the braid and wearing the teflon inner hose. That and you need to install the line to prevent movement the best you can.
I work for SPL Parts and we cater to the Nissan community, so I have alot of experience with the pro's and con's of what we sell. --- Just some credentials.
DeadEG is offline
Old 08-01-2004, 10:25 PM
impound's Avatar
Default Re: (DeadEG)
pix up
impound is offline
Old 08-02-2004, 01:22 AM
p-i-m-p right there
like I said, Im pretty sure they have a "guaranteed forever" policy and they will replace it for you
Old 08-02-2004, 01:30 AM
hatchling37's Avatar
You should have bolted that **** out of the way of your wheel when you installed it. That looks horrendous. That **** didn't just happen, dude, sorry...
hatchling37 is offline
Old 08-02-2004, 05:29 AM
impound's Avatar
Default Re: (hatchling37)
the triangle was bolted to the fork and the other piece was ziptied to the shock body.....teins dont have the bolt holes......."sobsob"..yeah right..i had a solid install with what i had
impound is offline
Old 08-02-2004, 05:51 AM
just throw some tape around it
b18bcivic is offline
Old 08-02-2004, 06:35 AM
Moderator
chad's Avatar
that LINE DID NOT BUST by itself.......
it was rubbed raw and thin and then busted....that will not be a warrenty [email protected]@@+++
chad is offline
Old 08-02-2004, 07:22 AM
sting94112's Avatar
Default Re: Anyone ever POPPED a Goodridge S.S. Brakeline?????????? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">that LINE DID NOT BUST by itself.......
</TD></TR></TABLE> i agree
sting94112 is offline
Old 08-02-2004, 07:51 AM
(teh)H2OUUP2's Avatar
Ditto looks like it was rubbing something...I have to check mine periodically, cause I have aftermarket suspension, and can't use orginal mounting bracket.
(teh)H2OUUP2 is offline
Old 08-02-2004, 08:27 AM
toolowsol's Avatar
Default Re: Anyone ever POPPED a Goodridge S.S. Brakeline?????????? (H2ouup2)
that is definatly from a shotty install... I havec 3 zip ties plus the stock hardware holding my lines where I want them so they wont rub...
toolowsol is offline
Old 08-02-2004, 08:28 AM
Jon V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 &raquo;</TD></TR><TR><TD CLASS="quote">
my brakes just went out on me </TD></TR></TABLE>
didn't you just get your car back?
Jon V is offline
Old 08-02-2004, 11:53 AM
Default Re: (Jon V)
****, that looks nasty.
Old 08-02-2004, 01:16 PM
owen_the_soyboy's Avatar
yes.
the NSX forums have horror stories of them busting, more often at the joint near the brake caliper fittings.
dirt/sand gets in betwen the stainless braids and the interior rubber hose.
then rubs a hole right thru, not good.
the rubber coated SS lines (like some neuspeed ones) are your best choice for a street car.
your looks like it might have rubbed on the fork or rotor?
owen_the_soyboy is offline
Old 08-02-2004, 01:18 PM
kommon_sense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">dont they have a "guaranteed forever" policy?</TD></TR></TABLE>
I don't see how anyone making stainless lines could have much of a guarantee. One of the things that happens with stainless lines is that dirt can work its way into the brake and wear a hole in the teflon inner liner. Most braided line manufacturers don't bother putting a protective rubber coating on the outside of the line to prevent this. So bottom line is if you run stainless lines, you need to inspect them regularly and replace as needed.
kommon_sense is offline
Old 08-02-2004, 03:27 PM
^I know what you mean...but all their lines have "guaranteed forever" in huge font on the front of the box.
Its even on the website.
Old 08-02-2004, 04:37 PM
impound's Avatar
i thought i had a proper install but now looking at it i t does look as if it rubbed through on the tire or the rotor...i'll inspect my other tomorrow and see....
impound is offline
  • Ask a Question
Question Title:
Description:
