00 civic si harness does not plug into p73 ecu?
Old 08-25-2004, 06:27 PM
CNSK's Avatar
Default 00 civic si harness does not plug into p73 ecu?
I have a 96 jdm itr going into 2000 dx civic. I got all my necessary bolt and mounts. I bought a usdm 00 itr removed immobilizer ecu. I just bought a 2000 civic si engine harness but only the gray and blue plug will fit the ecu and not the green plug. Do I need some sort of adapter or so? I plug this ecu into my dx wire harness and all three plugs right up but couldnt crank becuase I didnt swap out the pins. I tested this usdm p73 ecu on my buddy's 2000 teg and crank right up after you turn on the engine for a few sec. But why wont the civic si harness plug A(i believe, the green plug) will not fit the itr ecu except the other 2 will plug up and all three plugs from my dx wire plugs up? Need some help........thanks..
Old 08-25-2004, 06:29 PM
Luserkid's Avatar
Default Re: 00 civic si harness does not plug into p73 ecu? (Moua)
isnt the 2000 Si ecu harness OBD2b while the 96-97(98) ITR is OBD2a? I think thats where your problem is.
Old 08-25-2004, 06:30 PM
CNSK's Avatar
Default Re: 00 civic si harness does not plug into p73 ecu? (Luserkid)
but its the same year harness and ecu, which is 2000 obd2b.....
Old 08-25-2004, 06:36 PM
Luserkid's Avatar
I believe the si was the only one with OBD2b and all other honda civics had OBD2a Not sure, i have a 93 civic.
Check out this picture and see which ecu is with which harness. I would just hook the ecu up to your dx harness and add the wires that needs to be there.
Modified by Luserkid at 7:47 PM 8/25/2004
Old 08-25-2004, 06:41 PM
senpai's Avatar
Who told you 99-00 SI is OBD2a?
It is OBD2b
Old 08-25-2004, 06:47 PM
Luserkid's Avatar
Default Re: 00 civic si harness does not plug into p73 ecu? (maztur)
I thought so. Ehh to many different apps. Ill just stick with OBD1
Old 08-25-2004, 06:52 PM
CNSK's Avatar
Damn getting a headache off this ****... So what do you guys suggest for me to do? get a 2000 si ecu with jdm R engine (something Im really not happy about doing becuase its not to its full potential)? or as what luser kid said....run my dx wire harness and add necessary wires to my usdm itr ecu? just need some help.....all you 99-00 ek hybrid owners.....whats your setup and what should I do?? thanks
Old 08-25-2004, 07:09 PM
Smith Wise's Avatar
I would say just add the wires to the dx harness, but that's just me. I don't have any idea why the 00 ecu wouldn't work on the 00 dx harness, both are obd2b. go figure....
Old 08-25-2004, 07:21 PM
CNSK's Avatar
Default Re: 00 civic si harness does not plug into p73 ecu? (Smith Wise)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smith Wise &raquo;</TD></TR><TR><TD CLASS="quote">I would say just add the wires to the dx harness, but that's just me. I don't have any idea why the 00 ecu wouldn't work on the 00 dx harness, both are obd2b. go figure....</TD></TR></TABLE>
the thing is....00 ecu fits my 00 dx harness....but the 00 si harness only 2 plugs will fit the harness and 1 plug wont....which is the green plug...correct me if im wrong someone.....Ill try to take some pictures..
Old 08-25-2004, 09:26 PM
Built Beast's Avatar
nice picture of the of the pin outs "Luserkid" def. will have to save that.
Old 08-26-2004, 08:09 AM
CNSK's Avatar
anyone else?
Old 08-26-2004, 09:21 AM
dantastic's Avatar
run a chipped p28 with a obd2b-&gt;obd1 jumper harness
Old 08-26-2004, 09:54 AM
Nameless RB26's Avatar
Default Re: 00 civic si harness does not plug into p73 ecu? (dantastic)
Convert to OBD1. You'll be very happy once you did it.
Old 08-26-2004, 09:56 AM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">run a chipped p28 with a obd2b-&gt;obd1 jumper harness</TD></TR></TABLE>
I suggest this as well
Old 08-26-2004, 10:30 AM
Jackson's Avatar
The green plugs connects to your interior harness. The third grey plug is on your interior harness. I have the same car, same motor and same engine harness. It is all plug and play. If the usdm itr ecu fits your dx harness, it will fit your si harness as well. You'll understand when you pull the dx harness out. I thought the samething when I first picked up the si harness thinking it was missing a plug.
Old 08-27-2004, 08:38 AM
CNSK's Avatar
Default Re: 00 civic si harness does not plug into p73 ecu? (Jackson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jackson &raquo;</TD></TR><TR><TD CLASS="quote">The green plugs connects to your interior harness. The third grey plug is on your interior harness. I have the same car, same motor and same engine harness. It is all plug and play. If the usdm itr ecu fits your dx harness, it will fit your si harness as well. You'll understand when you pull the dx harness out. I thought the samething when I first picked up the si harness thinking it was missing a plug.</TD></TR></TABLE>
thanks man.....a load off my shoulder...
Old 08-27-2004, 09:15 AM
The King's Avatar
yeah that green plug goes to the int harness the 3 ecu plug is connected to the body harness
rsxdc52002
12
01-25-2009 02:51 PM
BLKCivicPorscheStyle*
08-22-2005 12:46 PM
rossc96
02-12-2005 07:01 AM
FAAST
11-09-2004 08:06 PM
busmcrs
01-09-2003 09:49 PM
Quick Reply: 00 civic si harness does not plug into p73 ecu?
