PROBLEMS WITH MY B16 LSD TRANNY
Old 08-25-2004, 07:28 PM
a
boostng r's Avatar
Default PROBLEMS WITH MY B16 LSD TRANNY
ok i got a b16 lsd tranny in my car its been shifting fine all of a sudden the next day its hard to get it in all the gears
it shift fine while the car is off and when the clutch is in when the car it is off i been running the gm oil
could this be a clutch problem of inside the tranny
and i have not raceed my car like in 1 month
Old 08-25-2004, 07:32 PM
a
boostng r's Avatar
tttt
Old 08-25-2004, 07:33 PM
Electrician
Deemeetree's Avatar
Hard to get into the gears as in grinding while going into a gear or as in you can't place the shifter in ANY gear?
Old 08-25-2004, 07:37 PM
a
boostng r's Avatar
it grinds sometimes when i try to put it in gear but it will let me select the gears but it verry hard to put it in gear
Old 08-25-2004, 07:45 PM
Electrician
Deemeetree's Avatar
Have you checked the condition of your shifter bushings? It's sometimes the simple stuff that causes the most headaches.
a
boostng r's Avatar
Default Re: (Dimi)
they are brand new energy bushings
Old 08-25-2004, 07:47 PM
Kamin's Avatar
Default Re: (b16coupe4)
check fluid level.
also physically get under the car and look at the bushings, dont just say they are new. one could have come out.
Old 08-25-2004, 07:48 PM
a
boostng r's Avatar
fluid level is perfect the bushings are perfect
anything else
Old 08-25-2004, 08:00 PM
a
boostng r's Avatar
ttttttttttttt
Old 08-25-2004, 08:02 PM
backdraft's Avatar
It is probably your clutch taking a ****. If all the other stuff the others said is cool. This may be the problem solver.
Old 08-25-2004, 08:04 PM
a
boostng r's Avatar
ok cool i just hope its not the inside of the tranny
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe4 &raquo;</TD></TR><TR><TD CLASS="quote">ttttttttttttt</TD></TR></TABLE>
DUDE stop bumping your thread every 10 minuets. if someone can help they will find it. if the fluid, linkage and bushings are good its the clutch.
if it only happened in 1 gear it would be the trans, if its all of them odds are its the clutch.
Old 08-25-2004, 08:11 PM
xerox445's Avatar
Default Re: (Kamin)
10 bucks your pressure plate is shot
Old 08-25-2004, 08:12 PM
a
boostng r's Avatar
ok thanks and sorry for trying to find out whats wrong with my expensive *** tranny
Old 08-25-2004, 09:38 PM
R you serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe4 &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks and sorry for trying to find out whats wrong with my expensive *** tranny </TD></TR></TABLE>if its so expensive and precious go take it to a profesional
i say its your fluid. my .02
Old 08-25-2004, 11:03 PM
a
boostng r's Avatar
i already check it its perfect and for profesionals thats what honda tech is here for i know how to do the work
Old 08-25-2004, 11:10 PM
_BEN_'s Avatar
Have you bled the clutch mc?? Maybe there is just not enough fluid to compress the pressure plate.
If its not that its probably your pressure plate.
Old 08-25-2004, 11:11 PM
a
boostng r's Avatar
Default Re: (_BEN_)
thanks i already check that i am gonna change the whole clutch everything brand new
lacking vtec
03-29-2007 03:29 AM
AzntstyleZ
06-27-2005 08:21 AM
B16X
08-11-2004 06:35 AM
underpressure02
05-11-2004 07:29 AM
rex_boy
03-17-2003 11:08 AM
Quick Reply: PROBLEMS WITH MY B16 LSD TRANNY
