HELP ME!!! Pulling codes 71, 72 , 73, 74 on a 98 civic
To make a long story short well, first i got a code 90 which was gas leak and after i fixed that i warmed up the car and the idle jumps around to 200 - 1000 - 500 basically it wasn't steady like how it was before so check the codes and got a code 71, 72, 73, 74 which is misfiring in cylinders 1, 2, 3, 4. what do i do now?? is the ecu messed up??? all the wiring is fine and plugs and caps is all in order because i tripple checked it
NEED SOME DEPREATE ADVICE IN HOW TO GO ABOUT SOLVING THIS PROBLEM...................................
Re: HELP ME!!! Pulling codes 71, 72 , 73, 74 on a 98 civic (JDMspecs Eg6'er)
are u positive u have the correct wiring scematics on how the plug wires go on the dist?
everything is good.................. the whole misfiring started when i had to check for a code when i got a code 90 then i accidently left the jumper wires in the service connector and thats when the new codes began........
Re: (JDMlyfestyle)
DriveSideWays
08-18-2004 07:27 PM
civickid99
05-08-2004 12:15 PM
