Anybody have closeup pics of ek sideskirts on an eg?
I know it has been covered many times but I want to see some closeup shots of how clean it looks. Some front and rear pics would be helpful. I am kind of scared of cutting them up.
Re: Anybody have closeup pics of ek sideskirts on an eg? (97itr86)
the rears will look fine you don't need to cut the rears. the fornt is where the cut is. ic utted mine but haven't got the front mudflaps to hide the cut in the front. but i test fitted it and drilled the new holes in the ek sideskirt. just waiting for the mudflaps
Re: Anybody have closeup pics of ek sideskirts on an eg? (eg92b16a2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg92b16a2 »</TD></TR><TR><TD CLASS="quote">the rears will look fine you don't need to cut the rears. the fornt is where the cut is. ic utted mine but haven't got the front mudflaps to hide the cut in the front. but i test fitted it and drilled the new holes in the ek sideskirt. just waiting for the mudflaps</TD></TR></TABLE>
So the mudflaps will cover it. In that cast I should just buy a stock replacement. I can't run mudflaps they just get ripped off.
1 Post
I put these EG HB skirts on my 4dr EG yesterday. Perfect fit. The clip in the front it on the right spot, for the other clips I drilled 10mm holes which I filed out a bit. That was the only modification needed.
The bit sticking out on the front has a small gap on top. I might put some EK mudflaps on.
.... yes, I know about the wing ...
Re: (SkoundrelUSA)
i definetly recommend them...
you gotta do a little bit of drilling, and squaring out of your holes...
but its worth it, just MEASURE AND MARK EVERYTHING PRECISE
