B16a Main bearing cap
Does anyone know the size of the bolt for the main bearing cap on a b16a? I know it is either 14mm or 15mm, but I wanna know what it is exactly. Thanks in advance.
Re: B16a Main bearing cap (Archidictus)
Same here. Thanks for the free bump. Does anyone know for sure? Someone has to have a helms with this info in it. I just busted 2 sockets trying to take these bolts off, and before I go buy some craftsman ones, I wanna know what size to buy.
Re: B16a Main bearing cap (DOHC4life)
The simple answer is, don't send a boy to do a man's job. Use 1/2 inch drive sockets for things like this and they won't break. You do have a torque wrench don't you? If you don't, you don't want to pull these caps off anyway. I'd buy a 14 and a 17 You know it's one or the other.
Re: B16a Main bearing cap (MasterKwan)
I don't need a torque wrench just yet. I won't be putting the caps back on. This block is screwed up bad, so I'm making a table out of it. But I need to get everything out of it to clean it off. The problem with the sockets breaking was that they were cheap no-name brand ones. I'm getting newer, better tools slowly but surely.
Unceasing Measure
You have an impact driver? Air gun? Don't be afraid to **** some **** up, although the crank will make a hell of a lamp post if you are so inclined .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">You have an impact driver? Air gun?</TD></TR></TABLE>
That would be a huge help.
I remember Ricey telling me that he just made a table out of a bare block. Im gonna steal that ish
Solbros Owns Me
Re: (Built to Spill)
They're 14 mm bolts.
Do this....take the 14mm socket and place by tself on the bolt, then wack the top with a hammer, then crack them loose
10 replies and not one person knows the size
aznej2
05-15-2007 07:01 PM
