Oil Filter Relocation Kit
Hi all, forgive me if this is a dumb question but what is the significance of ab oil filter relocation kit? One other question, how do you know what size throttle body to use? Thanks
Re: Oil Filter Relocation Kit (sorrule)
an oil reolcation kit is usually used to make oil changes easier (placing the filter someplace more accessible) and can also increase the oil capacity of the engine if you user a larger filter.
The size of your intake manifold will most likely determine the size of your throttle body.
1 Post
most oil filter relodcation kits have additional ports which can make the installation of an oil feed line, or oil temp/pressure gauge installs easier.
1 Post
Re: Oil Filter Relocation Kit (brcivic411)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brcivic411 »</TD></TR><TR><TD CLASS="quote">an oil reolcation kit is usually used to make oil changes easier (placing the filter someplace more accessible) and can also increase the oil capacity of the engine if you user a larger filter.
The size of your intake manifold will most likely determine the size of your throttle body.</TD></TR></TABLE>
dclub01
05-01-2003 03:22 PM
