Installed Apexi WS II on hatch with S.T. sway bars. Not to friendly.
Installed exhaust. I had to remove the rear sway bar end links inorder to get the can over the suspension. It bolted up fine after that. The front is another story. The cat is now lying on the front sway bar. I tried to loosen the bolts and readjust. But it's still no good. I've got rattles and vibrations. Got to do something tomorrow to fix this. Maybe add washers to the front sway bar mounts to lower sway bar.
I will be having a b18c installed soon. Probably add a test pipe. This should clear.
The exhaust itself is quiet. Just what I wanted. The paint or powercoating on the pipes scratches off easily. The kit came with all new bolts,washers and gaskets.
importboi22
23
05-04-2004 03:34 PM
