Converting civic to ABS
Re: Converting civic to ABS (Bad-T)
Are you trying to put ABS on your car?
If you are it will cost WAY more than it's worth and take WAY to much time. You have to change ALL of your brake lines, wire it up, get an ECU with ABS, and much more.
does anyone know what that website is where you can look up factory honda parts and buy them for discount? They have pretty in depth diagrams i was thinking I might be able to tell by looking at that. I just can't remember the name of the site.
my friend had all the stuffs that you need like abs modulator/hydraulic pump, controller, wheel sensors from his totaled gsr. i wouldn't do it, but if you want i can hook you up...
Re: Converting civic to ABS (2lua)
Cool, I already have the wheel speed sensors. I just need to find out if I am going to be able to hook them up to my 94 civic disk brake set up. (Im not actually trying to run full ABS, just the wheel speed sensors for ABS)
Re: Converting civic to ABS (93CivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI »</TD></TR><TR><TD CLASS="quote">It would be less expensive and simpler to sell your car and by one with the ABS unit installed....</TD></TR></TABLE>
please read the post. I just need to install wheel speed sensors. It is part of the ABS system, but im not doing the whole system!
ummm....yeah.....
you're gonna need EX sedan drive axles too.
If you have 4 wheel disc are you sure you don't already have ABS?
Re: Converting civic to ABS (devi1man)
Trust me, I definitly don't have ABS.
As for EX sedan drive axles.... The car has a GSR engine, and I am using Gator axles. My Gator dealer just informed me that he can add the ring on for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bad-T »</TD></TR><TR><TD CLASS="quote">Im not actually trying to run full ABS, just the wheel speed sensors for ABS</TD></TR></TABLE>
can you splain this a little more? Are you trying to set up traction control?
Re: Converting civic to ABS (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">
can you splain this a little more? Are you trying to set up traction control? </TD></TR></TABLE>
Im trying to set up a few things that require wheel speed. 2step, boost control & maybe TC.
agaf'd
15
04-03-2009 01:35 PM
scoobyghost
08-30-2004 06:15 PM
