broken knock sensor...
i just broke my knock sensor today...and i was wondering how big of a difference is a knock sensor on and off your car...?? even tho i got a bone stock d16y8..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">If the code registers it could throw your car into limp mode.</TD></TR></TABLE>
Im sure it will..its just a matter of time.
Your car will run terribly with a broken knock sensor.
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Your car will run like absolutely **** if you have a broken knock. or you could do a OBDII>OBDI conversion</TD></TR></TABLE>
instead of doing all that cant i just replace the knock sensor?
Risky Business
Re: (DiSbaDbOi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DiSbaDbOi »</TD></TR><TR><TD CLASS="quote">
instead of doing all that cant i just replace the knock sensor?</TD></TR></TABLE>
Yep
Yep
Re: (JDMlyfestyle)
that would explain why my car runs like *** right now :D it likes to bog down a lot and then speed up... i won a knock sensor on ebay and im waiting for them to mail it now... hopefully that will get rid of my CEL and make the car run better
Re: (inane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inane »</TD></TR><TR><TD CLASS="quote">that would explain why my car runs like *** right now :D it likes to bog down a lot and then speed up... i won a knock sensor on ebay and im waiting for them to mail it now... hopefully that will get rid of my CEL and make the car run better</TD></TR></TABLE>
uh
why not look at the CEL? it could be completley unlreated to the knock sensor.
it never ceases to amaze me people just throw parts at a problem without diagnosing it.
uh
Re: (Kamin)
er, i guess i worded what i said wrong... i did diagnose it and my CEL is for the knock sensor... what i meant was that i was hoping that when i replace the knock sensor, that it will make my CEL go away... because im annoyed with it and i want it gone right now...
You can get used knock sensors, they still cost a bit but who knows how reliable they are...and new ones are well over $100. Why not use the cash to pick up a P28 ecu which doesn't look for a knock sensor? Another $74 for the OBD1 conversion harness and you're set.
Re: (klungemonger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger »</TD></TR><TR><TD CLASS="quote">You can get used knock sensors, they still cost a bit but who knows how reliable they are...and new ones are well over $100. Why not use the cash to pick up a P28 ecu which doesn't look for a knock sensor? Another $74 for the OBD1 conversion harness and you're set.</TD></TR></TABLE>
so if i was to go OBD2-OBD1 i wouldnt need a knock sensor?
Re: (DiSbaDbOi)
so if i was to go OBD2-OBD1 i wouldnt need a knock sensor?</TD></TR></TABLE>
As long as you use a P28 that is correct. Also if you have OBD1 you can think about ecu mods down the road.
