Good tranny fluid...Whats your recommendation? (getting slight 3rd gear grind)
B A N N E D
I have a 2000 Civic Si and just recently 3rd started to grind. If I shift slowly, it wont do it...however anything above 5,000 rpms...causes a slight grind normally shifting into 3rd.
Ive read a few previous post and remembering people occuring this same problem, however changing over to a nice tranny fluid..sometimes made it go away.
Any of you guys recommend a certain tranny fluid, that make this problem go away? If so, what and where do I buy this fluid?
Thanks for any help you can provide
B A N N E D
Re: Good tranny fluid...Whats your recommendation? (BauleyCivic)
Thanks BauleyCivic, You gotta stop helping my slow *** out so much...Imma gonna owe you a "Bentley" by the end of year..the rate Im goin
Thanks again guys..
Thanks again guys..
B A N N E D
wow, I just called Chevy..and they said its 22.00 a quart! Is that what you guys paid for it?
Location: Just Drank A 5th of VODKA Dare me to drive, Ca, u.s.
Re: Good tranny fluid...Whats your recommendation? (collateral)
if that;s too much for you you can also try the penzoil syncro shizzle too, it worked my me...and my buddy
difference between syncromesh, and syncromesh FM?
Because I just put a quart of regular syncromesh into my car.
cute little bastard
Honda Manual Transmission Fluid sucks ***. Should've got the Sychromesh but I'm a cheap bastard. Don't go cheap like me.
Re: Good tranny fluid...Whats your recommendation? (SkoundrelUSA)
syncromesh and honda tranny fluid is about the same. friction modified is used on LSD trannys but you can use it on your regular.
Re: (ejprimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo »</TD></TR><TR><TD CLASS="quote">gm syncromesh part# 12346190 </TD></TR></TABLE>
this is the full synthetic syncromesh made by castrol. you can get it for $11-12/qt. at gmpartsdirect.com
B A N N E D
Re: (egtype-r)
thanks for all the responses guys,
So what its come down too ...is should I buy the GM sychromesh or Redline Tranny fluid?
Any experience both? If you like Redling oil better...what exact model did you get and if so..what is the part number?
I just want to experience and "try" to get rid of the grind...I dont really care of the cost factor.
Thanks guys again for all your knowledge and help
Re: Good tranny fluid...Whats your recommendation? (AllDsD1motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllDsD1motor »</TD></TR><TR><TD CLASS="quote">$22....... that sounds right....</TD></TR></TABLE>
$22 is WRONG!! Get it for $12/qt at gmpartsdirect.com.
Re: Good tranny fluid...Whats your recommendation? (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa »</TD></TR><TR><TD CLASS="quote">
$22 is WRONG!! Get it for $12/qt at gmpartsdirect.com.</TD></TR></TABLE>
****, I payed $28/qt.
Solbros Owns Me
Re: Good tranny fluid...Whats your recommendation? (Inspector Gadget)
wow, I get that stuff for 8 bucks a quart....maybe I should buy a bunch and sell it to you guys
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">GM Synchromesh Friction Modified
B A N N E D
Re: (ejprimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo »</TD></TR><TR><TD CLASS="quote">gm syncromesh part# 12346190 </TD></TR></TABLE>So guys is this the one I should order?? Is this the Sychromesh FM?
