Can I pass smog with a cracked manifold?
Old 11-30-2004, 11:44 PM
Achenar's Avatar
Default Can I pass smog with a cracked manifold?
So I need to smog my car ASAP, and I get a CEL .. O2 sensor. I take the heat shield off, and see this:
Now, obviously this looks pretty goddamn nasty.
However, I really DON'T want to buy another freaking manifold, especially since I'm swapping the engine after I pass smog.
Can I just replace the sensor, and will I get away being able to pass smog with a huge crack like that on the manifold?
-a
Old 11-30-2004, 11:46 PM
xkpjokerx's Avatar
Default Re: Can I pass smog with a cracked manifold? (Achenar)
just pay somebody off to pass you...
Old 11-30-2004, 11:51 PM
sheepey's Avatar
JB weld that **** !
Old 12-01-2004, 12:04 AM
Br1anPham's Avatar
Default Re: (sheepeg3)
Most likely it won't affect your o2 readings, but you never know.
Old 12-01-2004, 12:05 AM
E-brake or Handbrake's Avatar
I've got a good non-cracked manifold for sale. Only $40, guaranteed in working condition. I'm in socal.
Or I could let you borrow it with a deposit?
Old 12-01-2004, 12:07 AM
jerbear!'s Avatar
weld it and cross your fingers
Old 12-01-2004, 12:28 AM
trooper0641's Avatar
Default Re: (jerbear!)
ill give you my manifold for $20
Old 12-01-2004, 01:19 AM
4dohs4mohoes's Avatar
I have a cracked manifold too, but i dont need to worry about smog. JB weld doesnt work. (already tried it) and you can weld cast iron to last
Old 12-01-2004, 01:59 AM
94_HATCH's Avatar
Default Re: Can I pass smog with a cracked manifold? (xkpjokerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkpjokerx &raquo;</TD></TR><TR><TD CLASS="quote">just pay somebody off to pass you...</TD></TR></TABLE>
Old 12-01-2004, 04:08 AM
chris_c's Avatar
toss the heat shield back on and go get tested. since smog tests are tail pipe end the car will probably give better results with the cracked manifold as the hydrocarbons, CO and NOx are being pumped out pre-cat and never reach the sniffer... lol
Old 12-01-2004, 04:10 AM
94_HATCH's Avatar
Default Re: Can I pass smog with a cracked manifold? (chris c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris c &raquo;</TD></TR><TR><TD CLASS="quote">toss the heat shield back on and go get tested. since smog tests are tail pipe end the car will probably give better results with the cracked manifold as the hydrocarbons, CO and NOx are being pumped out pre-cat and never reach the sniffer... lol </TD></TR></TABLE>
Thats nice and all but you CANNOT take a smog test with a CEL. At least thats how it is in California
EDIT: I just noticed original poster is from SD. If you need another 4 wire o2 sensor hit me up, Im local
Old 12-01-2004, 04:14 AM
chris_c's Avatar
Default Re: Can I pass smog with a cracked manifold? (94_HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_HATCH &raquo;</TD></TR><TR><TD CLASS="quote">
EDIT: I just noticed original poster is from SD. If you need another 4 wire o2 sensor hit me up, Im local </TD></TR></TABLE>
i'm NY and we are relaxed compared to cali so idk.... can you just pop the bulb out of the CEL?
Old 12-01-2004, 04:23 AM
94_HATCH's Avatar
i'm NY and we are relaxed compared to cali so idk.... can you just pop the bulb out of the CEL?</TD></TR></TABLE>
Depends on what type year civic he has. I know the 92-95 civic clusters dont have a bulb for the cel. I think its an led thing inside the actual cluster.
Old 12-01-2004, 04:50 AM
kay_animation's Avatar
Call honda because that header is under warrenty in our cars and the warrenty was extended to 150K miles. Mine cracked before at about 105K miles and honda replaced everything for free, so do that first.
As far as emissions, you should be fine. I don't think they pop your hood. They didn't on mine. The only way it will hurt is if its like mine was, when the header cracked, the idle was crazy as hell and I kept getting o2 sensor cels, so in that case, the random motor idling might make you fail.
But you could always try. Its free till you pass
Old 12-01-2004, 06:29 AM
AutoXer's Avatar
When I've had my car tested in NY and MA, they hooked up to the ECU to read any codes. If it comes up with anything, you fail. Of course, some of the hick areas in NY don't bother, but MA is all computerized, and I'd assume CA is the same.
Old 12-01-2004, 06:38 AM
chris_c's Avatar
Default Re: Can I pass smog with a cracked manifold? (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
callin me a hick???
lol... all computerized here too [i get inspected in westchester cty.]
Old 12-01-2004, 07:13 AM
MugenHonda's Avatar
Location: With my POS D15B2, Whereever whenever, United States
yeah you're f$cked
All NJ and NY connect to your diagnostics ports, so if and when they plug it in and you still havea cell, you'll fail. I assume though that since there is a crack, your highly likely to pass because like the guy above said, less emissions will be come from your exhaust
hehe
Old 12-01-2004, 07:34 AM
cnyej1's Avatar
Default Re: Can I pass smog with a cracked manifold? (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">yeah you're f$cked
hehe</TD></TR></TABLE>
Not all NY... downstate was the only part of NY that actually did diagnostic checks up until today Dec 1st.... now all of NY state is required to diagnostics on all OBDII cars.... so everyone 95 and down is cool...
Old 12-01-2004, 08:18 AM
Achenar's Avatar
Default Re: Can I pass smog with a cracked manifold? (kay_animation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kay_animation &raquo;</TD></TR><TR><TD CLASS="quote">Call honda because that header is under warrenty in our cars and the warrenty was extended to 150K miles. Mine cracked before at about 105K miles and honda replaced everything for free, so do that first.
But you could always try. Its free till you pass </TD></TR></TABLE>
If this is true, it's great news! Going to call Honda now!
-a
Old 12-01-2004, 08:48 AM
Achenar's Avatar
Honda Dealership claims the part is warrantied for 80k miles!
Good think I'm just a hair under 79k miles!
-a
Old 12-01-2004, 04:52 PM
97civicdx's Avatar
I just went thru inspection and they didnt plug into the diagnostic port. NJ inspection that is
Old 12-01-2004, 04:57 PM
DAguyLS's Avatar
in pa, it varies from county to county. Some counties don't even have emissions in pa
Old 12-01-2004, 05:12 PM
TTM
TTM's Avatar
i live up in idaho, ive never even heard of a smog test!
sux t0 b3 U!
Old 12-01-2004, 05:13 PM
civic99b16a's Avatar
Default Re: (slamdcivic)
you definiatly wouldn't pass the reason you have a cel light is cause on every exhaust has back pressure the flow of the exhaust gasses will pull air throughafter every exhaust stroke then the o2 will detect that the a?f ratio is to lean and try to comp for it when it doesnt see the reading getting afftected by the increase fuel mixture it will set a cel and you should probably notice your car running shitty also because of the ecu trying to correct the lean condition it will make HC emmisions high and probably making the cat work way to much trying to clean that rich mixture up so Nox emmision would fail as well
Old 12-01-2004, 05:14 PM
Default Re: (civic99b16a)
plus Nox is the one there really strict about beacuse when Nox gasses mixes with sunlight it causes smog
STREETFIGHTER50
01-07-2013 09:02 AM
b20vtech
02-05-2009 01:02 PM
lv6l
12-08-2005 09:59 PM
ninjlao
05-18-2005 12:16 PM
Quick Reply: Can I pass smog with a cracked manifold?
