Tilted hatchback
Tilted hatchback
what would cause a eg hatch to still be slightly higher on the passenger side if the frame is straight.. ( had a wreck three years ago) replaced struts and springs are fine..
To make it more interesting I put it on stands and its level all the way around so I know that it has something to do with the suspension just the fact of what??
Re: Tilted hatchback (biotech0123)
was the car hit on the pass side in the wreck?
could have jarrd something in the suspension.
it could be a number of things besides the frame being bent
Re: Tilted hatchback (chads)
Body shop fixed it already, the damage was done from me smacking a curb to avoid hitting some dumb *** that turned in front of me.. The reason being for the body shop not fixing it is because I asked him only to get the body straight and I'll do the rest do to the funds that was available to me at that time.. would post pics but my scanner is down as of now
Re: (nowaywhatthehell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowaywhatthehell »</TD></TR><TR><TD CLASS="quote">Just take it to a Honda Dealership.</TD></TR></TABLE>
Re: (mercuryfrost)
Every Civic I've ever seen sits a little lower on the drivers side if it doesn't have coilovers. The constant extra weight on the drivers side makes it sit a little lower.
1 Post
Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Every Civic I've ever seen sits a little lower on the drivers side if it doesn't have coilovers. The constant extra weight on the drivers side makes it sit a little lower. </TD></TR></TABLE>
Re: (93CivicSI)
im thinking its the weight of the tranny that gets it level I put the tranny in and had someone sit in the front bout were the motor sits and its fine..
Im I being paranoid
Im I being paranoid
Re: (biotech0123)
don't take it to the dealer, they charge like 40 bucks just to have someone look at it. take it to a good local body shop and they should be able to give you a estimate.
I hope that's true. Mine sits maybe half an inch higher on the front passenger side and it looks like it's just a bit higher than the rear is..My car was smacked in the front before though.
my car was a half inch heigher on the passenger front too after i lowered my car. now for some reason it's pretty even. i thought i was the only one that had that problem. and my car has never been in a wreck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowaywhatthehell »</TD></TR><TR><TD CLASS="quote">my car was a half inch heigher on the passenger front too after i lowered my car. now for some reason it's pretty even. i thought i was the only one that had that problem. and my car has never been in a wreck</TD></TR></TABLE>
Are you on springs or coilovers? I'm getting new coilovers just to make it a bit more even.
i was wondering y my car was like that. good job and thanks
So what should I do, raise the driver side a little or lower the passenger side a little?
Re: (carbing'ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbing’ed »</TD></TR><TR><TD CLASS="quote">are you fat?</TD></TR></TABLE>
No
No
Re: (carbing'ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbing’ed »</TD></TR><TR><TD CLASS="quote">well if u are or arent, could be ur springs settling more on the side where more wieght is</TD></TR></TABLE>
I've had several different sets of springs already. Same thing.
Re: (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">Are you on springs or coilovers? I'm getting new coilovers just to make it a bit more even.</TD></TR></TABLE>
i'm on H&R springs. coilovers would be sweet
Anyone know what corner should I raise or lower? I put on some coilovers and when they are all set even on the sleeve it still sits the same.
Re: (chowmien)
Raise the front drivers, I lowered my whole pass side. Or have your car on a level surface and have someone measure the wheel well height from the ground then figure from there what you have to lift or lower.
