low idle help
low idle help
since i have done the minor mods to my 98 ex (i/h/e) i have notice at times my idle going down to like 200 or so rpm. what would be causing this. most of time time it idles in the 5/800 rpm range. should I check my timing? am I running to lean? i just am not smart enough to figure this out.
If you haven't adjusted or changed anything that would affect your idle, try taking off your iacv and cleaning it, this can somethimes help in this situation. If that doesn't work, report back.
Re: low idle help (Falqon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falqon »</TD></TR><TR><TD CLASS="quote">just out of curiousity, how do you know it's dropping to 200rpm?</TD></TR></TABLE>
is it 200 RPM above the lowest mark. the lowest mark is 500 so that means it idling about 700. if your car is idling 200, then your car would shake like crazy struggling to live.
Re: (Falqon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LadyExotic »</TD></TR><TR><TD CLASS="quote">
is it 200 RPM above the lowest mark. the lowest mark is 500 so that means it idling about 700. if your car is idling 200, then your car would shake like crazy struggling to live.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falqon »</TD></TR><TR><TD CLASS="quote">really? Cause my gauges don't go that low,</TD></TR></TABLE>
exactly.
exactly.
they make rpm gauges that you can hook up that are more accurate, and they even make digital ones to me even more accurate
what i'm talking about isn't an on board component
Paprika
05-08-2007 03:18 PM
manyakiexpi
02-18-2006 11:45 AM
lshatch92
21
10-28-2005 06:38 PM
