New exedy clutch kit installed...grinding still?
Old 04-13-2005, 11:28 AM
ferby's Avatar
Default New exedy clutch kit installed...grinding still?
Ive got a 97 civic hx ...
I just replaced my clutch with an exedy clutch kit and when shift into reverse it still grinds...and shifting into first still is a struggle of some sort.? any suggestions to why this might be happening... i thought the new clutch would fix all of this, guess not....my mechanic said their was no need to resurface flywheel he said its still in good shape.
all comments appreciated?
Old 04-13-2005, 11:30 AM
HT Order of Merit
JDM_Ej's Avatar
Default Re: New exedy clutch kit installed...grinding still? (ferby)
Seems pretty common. Are you trying to put it into first while your rolling? Because it doesnt like that lol.
Old 04-14-2005, 10:31 AM
ferby's Avatar
Default Re: New exedy clutch kit installed...grinding still? (JDM_Ej)
no im shifting from neutral to first not in motion.
Old 04-14-2005, 10:37 AM
pdiggitydogg's Avatar
REALLY should have had that flywheel resurfaced...think about it
Really clean smooth surface
Really dirty not-so-smooth surface
....Not wise.
Was the throwout replaced too? Did you adjust the rod above the clutch pedal?
Old 04-14-2005, 11:26 AM
RARE_EG2's Avatar
as far as putting it in reverse and it kinda grinds..if your at a complete stop and need to go in reverse..try putting the car in 1st gear then shifting into reverse..but with the clutch down the whole time before you are ready to actually move in reverse..then once in reverse..you may release the clutch and so on..for some odd reason..it helps going into reverse..
Old 04-14-2005, 11:37 AM
toEknEEg's Avatar
Default Re: New exedy clutch kit installed...grinding still? (JDM_Del_Sol)
replacing a clutch really wont get rid of the grinding. the only thing the clutch may have done is that you didnt bleed the clutch enough so that the clutch wasnt fulling engaging thus giving you a grind going into gear
try bleeding your clutch....
you will know if your clutch is gone if you can't get into gear at all or you will barely start the car
if thats not it.... your syncros might be shot...
Old 04-14-2005, 11:39 AM
Tru
Tru's Avatar
I'd say syncros. If its grinding, a clutch isnt gonna fix it. syncros are relatively cheap, but the work is a pain in the ***
Old 04-14-2005, 12:11 PM
ekb16's Avatar
carbon coated syncros from gearspeed.com
snoopaloop986
07-17-2013 02:55 PM
lswantsvtec
06-25-2007 09:37 PM
CLE
09-19-2006 04:30 PM
lude98SH
02-21-2006 07:28 AM
ferby
04-19-2005 07:24 PM
Quick Reply: New exedy clutch kit installed...grinding still?
