93 vx swap question
93 vx swap question
Just got done swapping in a d16z6 in my vx. I'm running the vx harness, and a p28 ecu, Its running great just need help on the o2, vx harness is a 5 wire and the d16z6 has a 4 wire o2, Any help on wiring this up? or a diagram of the vx harness?
Or can you even run the vx harness with that motor????
tried searching and came up with nothing.
Re: 93 vx swap question (slowbluhatch)
Here you go
http://www.hondaswap.com/forum...14242
That's what I used when doing the exact same swap.
Re: (92lxsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92lxsedan »</TD></TR><TR><TD CLASS="quote">Dont forget about your vtec wiring</TD></TR></TABLE>
A vx is already vtec.
LOCATE THE 6 PIN PLUG BELOW ON THE PASS. SIDE VX SHOCK TOWER
The wires are in the following order:
ORG/BLU BLU/GRN WHT/BLK
BLU/YEL WHT/BLU YEL/WHT
REMOVE THE FOLLOWING WIRE FROM THE 6 PIN VX PLUG
ORG/BLU - O2 SENSOR
LOCATE THE 10 PIN PLUG PICTURED BELOW THAT IS ON THE VX SHOCK TOWER
BRN/BLK EMPTY BLK/RED
ORG WHT ORG/BLU WHT/BLU
BLU/GRN BLU/YEL EMPTY
REMOVE THE RUBBER PLUG FROM THE UNUSED SOCKET
INSERT THE ORG/BLU (O2 SENSOR) WIRE INTO THE SOCKET BETWEEN THE BRN/BLK WIRE AND THE BLK/RED WIRE. (TOP CENTER SOCKET IN PIC)
ORG/BLU - O2 SENSOR
lshatch1.8
13
08-14-2007 01:42 PM
cueballsi
12
12-18-2006 05:12 AM
