Need some help with identifying tranny
Re: Need some help with identifying tranny (SoOHiGH)
there should be few number's and letter's above the drain plug..in a little circle...one of then should start with a or b which is it ?
Re: Need some help with identifying tranny (drevinder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drevinder »</TD></TR><TR><TD CLASS="quote">there should be few number's and letter's above the drain plug..in a little circle...one of then should start with a or b which is it ?</TD></TR></TABLE>
you mean right here?
because theres nothing in the circle.
Re: Need some help with identifying tranny (Mario.)
this is at the top
then this is at the bottom
Heres where its located
Heres where the P80 is at
all I can tell from the pics is that it is a b-series trans. ysk must be the company that casts the casings, that stamp is on every trans. the # on the clutch fork doesnt mean anything.
If there is no stamping or vin# plate, you will need to take it apart and start counting teeth, or put it in the car and check rpm in each gear at a certain speed.
on both of my hatches.. there is a barcoded sticker (which can fall off) with a number on it right next to the engine block code (s/b near where tranny meets block). hope that helps.
Re: Need some help with identifying tranny (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power »</TD></TR><TR><TD CLASS="quote">all I can tell from the pics is that it is a b-series trans. ysk must be the company that casts the casings, that stamp is on every trans. the # on the clutch fork doesnt mean anything.
If there is no stamping or vin# plate, you will need to take it apart and start counting teeth, or put it in the car and check rpm in each gear at a certain speed.</TD></TR></TABLE>
how many teeth is it suppose to have for a b16 trans and what rpm/mph im suppose to be at with a b16 trans. 4000rpm = 80mph ?
G U E C O
09-14-2003 12:58 AM
