removing crankpully bolt with engine out of car?
anybody ever done this? i have no engine stand and was wondering how hard it woul be to do? i know it takes a lot of torque (6ft breaker bar) woudl this be hard to do?
quick response would be appreciated and i searched
Re: removing crankpully bolt with engine out of car? (CRXified)
help out?
anybody ever take the crank pully bolt out of a b16 when the engine is out of the car???
im wondering the same damn thing. DONT PUT A FORK IN THE FLYWHEEL BOLTS EITHER HAHAHA..
god im an idiot
still cant take the pulley off.
god im an idiot
Re: removing crankpully bolt with engine out of car? (ssbpturbohatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssbpturbohatch »</TD></TR><TR><TD CLASS="quote">do you have the tranny off??</TD></TR></TABLE>
tranny is still on
tranny is still on
Re: removing crankpully bolt with engine out of car? (ReD . EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReD . EK »</TD></TR><TR><TD CLASS="quote">
god im an idiot
ur words not mine
god im an idiot
ur words not mine
Re: (ekb16)
thanks a lot i knew of those 2 ways, but the thing i was really worrying about is how hard is it going to be to keep the engine planted on the palet while trying to torque that ****** off.. its gonna be rough i think, i got no engine stand
when i took off my flywheel when it was out of the car.. it took 3 ppl to take all the bolts off...1 guy layin on top of the motor, 1 guy holdin the flywheel, 1 buy wit the breaker bar breakin lose the bolts..lol..good luck
Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">when i took off my flywheel when it was out of the car.. it took 3 ppl to take all the bolts off...1 guy layin on top of the motor, 1 guy holdin the flywheel, 1 buy wit the breaker bar breakin lose the bolts..lol..good luck</TD></TR></TABLE>
haha sounds like a helluva good time, i guess my moms 300 lbs mechanic bf will have to lay on the motor, or hang on the breaker bar lol
thanks for the help ekb16, gonna tackle this saturday
1 Post
Re: (vtec y0)
I used an impact wrench to break it loose, but I also had an open end wrench holding the flywheel steady... You thread a screw through the box end of the wrench to the engine side of the bellhousing, then you rest the open end of the wrench on one of the flywheel pegs - thus preventing the flywheel from turning. It would be much easier with a picture, but it's a very simply idea if you have the tranny removed.
Since the engine is out of the car, using a long breaker bar is next to impossible as the engine itself is going to be moving all over the place.
You can rent impact guns from Home Depot (heh, I work there) and I'd also recommend buying a cheap propane torch. If the gun doesn't get off the bolt in your first couple tries, heat up the bolt for a couple minutes and then try again. You'll get it off, it just takes time. Good luck!!!
Re: (MrTodd)
thanks a lot, ill try that and a picture would be sweet for what ur talking about too, but it doesnt matter ill figure something out
Re: (CRXified)
I took a piece of 1/4" thick 2" wide and 20"s long flat stock and welded two bolts to it head end down. The bolts are spaced to fit in the holes on the crank pulley. Works great. I have also heard of people using strap wrenches.
Use a cargo strap to hold it on the pallet. I hve my engine presently sitting on a pallet and I straped it down when I pulled my crank pulley off to do my timing belt. The weight of the engine should hold it in place and keep it from sliding just make sure the straps are tight.
i just bought on eof those korean made ebay style crank pulley tools and had one freind use that while i busted out the 2ft breaker bar, only took like 30 secs to get it off, by the way my engine was out of the car
Re: (SOHCD16y8)
use several links of a CHAIN (from HOME DEPOT), bolt one end to where one of the pressure plate bolts (on flywheel) and on the other end bolt to the starter is bolted (block side). make sure bolts are threaded down snug. use a big breaker bar and have someone hold the block. you can also remove and torque your flywheel that way too.
jbell
01-06-2005 10:55 AM
