Serious Wiring Problems.
OK, So I put the 97 b18b1 in the 94 civic I am using the 97 integra harness. I pluged in all the plugs I can find. There are still alot of plugs left. I dont know what I should do. There is no power to the starter when I turn the key. You can here a click under the dash but that is it. Also the Vafc doesnt turn on wich is making me believe that I am not getting any power to the computer. What could be wrong and why is there so many left over plugs? Thanks
Re: Serious Wiring Problems. (slowrider94)
OBD1 and OBD2 owns you...I'm not too sure if you can use the 97 harness or should you use your factory harness but if you do a quick search you will find your answer.
Re: Serious Wiring Problems. (Lee_Delso)
you shoulda just used the DX harness on the old motor your ripped out..changed alt and dizzy componets....and injectors...and your set....make life hard tho....
johnjw
01-28-2008 12:59 PM
