AM i over doing it??
Location: Where we rock teh dookies, Nor Cal, You Es of EY
Im getting a JDM D15b vtec and would it be a good idea to get all new gaskets?
The motor is guaranteed to have 60k or less with most likely 30k or less.
Am i going over board by changing all the gaskets before the swap?
Re: AM i over doing it?? (Mattmob)
its never a bad idea to replace gaskets, in my opinion now would be the best time to do it. The motor is not in the car making it easy to access any part of the motor instead of craming your hands down into tight spots etc.
Re: AM i over doing it?? (92lxsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92lxsedan »</TD></TR><TR><TD CLASS="quote">its never a bad idea to replace gaskets, in my opinion now would be the best time to do it. The motor is not in the car making it easy to access any part of the motor instead of craming your hands down into tight spots etc. </TD></TR></TABLE>
i do agree with that
since you're getting a new engine for the car, and truthfully have no knowledge of how it was treated before you, i would say changing all the gaskets would be a good thing to do.
you wouldn't want to build a building on a shoddy foundation, would you? same applies here. make sure your base is strong before you go adding mods and other things.
SO i guess my nex t question would be;
WHich gaskets to use? I was told to use a d16 gasket on the head, but what about the other areas such as IM and exhaust manifold?
Thanks again!
Thanks again!
cool guy name
Re: (Mattmob)
I'm gonna go against the crowd on this one. I wouldnt change the head gasket(if its not broke dont fix it), if the gasket/seal is not leaking then i wouldnt worry about it.
Now timing belt and water pump I would do.
cool guy name
Re: (dohcVTECeg2)
if you feel like ripping down the motor then knock yourself out, is it necessary? Prob not unless there is an obvious problem.
Timing belt and water pump are crucial to making your engine work, if the timing belt goes the motor goes.
Re: (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">if you feel like ripping down the motor then knock yourself out, is it necessary? Prob not unless there is an obvious problem.
Timing belt and water pump are crucial to making your engine work, if the timing belt goes the motor goes. </TD></TR></TABLE>
yeap. i'd do the rear main seal, waterpump, t-belt. the headgasket isn't any harder to do while the motor's in the car.
ReactioN
30
09-06-2008 10:42 AM
