what mounts do i use and what one can i leave b18c1 into ek ******
i am going to put a obd1 gsr swap into my 96 ek ex what do i need i no i need 99 si linkage and ecu adapter also for dis.. but what mounts ????
Re: what mounts do i use and what one can i leave b18c1 into ek ****** (JDM99DC2)
99 si mounts. obd2 distributor unless u want to rewire. b series axels. b series tranny. extend some wires (forgot which ones). most will plug in thanx to honda for putting b16 into them si's.
Re: what mounts do i use and what one can i leave b18c1 into ek ****** (98B00STED)
Mounts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Hx Coupe »</TD></TR><TR><TD CLASS="quote">A/C Mount - You can use the stock B18 but if you want A/C you will need the bracket from a 99-00 Si, Delsol VTEC, or CRV.
Front Tranny Mount - Need the one for whatever tranny you're using and you can reuse your stock civic rubber.
Rear Tranny Mount - Need a bracket from a 99-00 Si and you can reuse your stock rubber.
Top Tranny Mount - Reuse all your civic stuff here, bracket and rubber.
Drive Side Top Mount - Need a 99-00 Si Bracket (piece with 2 studs) and you can reuse your stock rubber
Shift linkage you can use the one from the GSR, it's the same thing as the Si's.
Wiring, reuse your stock harness and just change any plugs that dont match on the sensors on the GSR motor. A few examples.
Dizzy - Change Plugs
IAT - Change Plugs
Wire IAB's
Wire VTEC Oil Pressure Switch
Wire VTEC Solenoid
Wire Knock Sensor
There might be something else for wiring but that's most of it there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED98 »</TD></TR><TR><TD CLASS="quote">99 si mounts. obd2 distributor unless u want to rewire. b series axels. b series tranny. extend some wires (forgot which ones). most will plug in thanx to honda for putting b16 into them si's. </TD></TR></TABLE>
It will not plug in because he is using an OBD I motor in an OBD II car so it's gonna take a little more than extending some wires.
IAT - Change Plugs
Wire IAB's
Wire VTEC Solenoid
Wire Knock Sensor
