Del Sol Guys -- Little help/insight here.
I'm going to see about buying a [shitty] Del Sol shell from this guy for 200.00 dollars. It's stripped down, no motor, no interior.. that kinda thing. But it's supposedly straight. It's basically a ROLLING shell, all aside from one control arm.
What I want to know is:
- Will civic interior basically fit inside of this thing? That goes for the dash and door panels. I'm sure every part won't fit, but will most of it? I'd rather have Civic interior of it's cheaper.
- Will Civic suspension fit this car? Like all of it? Axels and such. I'm almost 100% sure it does but it never hurts to make sure and ask.
- I just noticed that it doesn't have windows.... Will windows from a CIVIC work as replacements by chance?
That's all for now. Thanks alot.
You need del sol dash and bascially all interior and windows.
The seats are up to you , if use any type of civic seats u will sit alot higher than normal, del sol seats sit on the floor.
The rear and front civic suspension will work perfectly.
PM me if u got any other questions.
Re: (Darren90teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darren90teg »</TD></TR><TR><TD CLASS="quote">and i believe a eg hatch front suspenision will work but i think the rear is different?? not tottaly sure someone correct me if im wrong?</TD></TR></TABLE>
Civic Suspension will work front and rear
Re: (Del Sizzle)
correct me if im wrong, though this wasnt part of his question, but cant you use a teg dash? i thought i saw a write up on this somewhere, or was that a teg dash in an EK?
Re: (Del Sizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sizzle »</TD></TR><TR><TD CLASS="quote">Civic Suspension will work front and rear</TD></TR></TABLE>
92-95 Civic suspension. At least for the most part.
You can also use some Integra components (since I have ITR rear LCAs).
Re: (Apocolipse269)
I was attempting a Teg dash swap... trust me... unless your prepared to start hacking into your steering column support section then go for it... I decided to scrap the whole idea and just chuck the Sol dash in again.
Re: Del Sol Guys -- Little help/insight here. (Civic Hx-T)
if all else fails i had to replce the back end on my del sol and i got the parts off of a Acura Integra and it fit fine
i swapped everything from my 95 sol vtec to my 97 hatch dx
i mean everythin except the interior panels and stuff
the complete rear suspension, rear disc, minus lower arms to narrow from the sol
the front brakes swapped over with the knuckle
engine and trans worked well with a few wiring nightmares
but to answer your ? YES everything swaps except the interior stuff and the glass
always thought about swapping the top too
wickedj05
05-15-2016 08:12 PM
slammeddime
02-16-2013 05:50 AM
