one man brake bleeder kits
maybe the kit includes a check valve so no air gets back into the lines?
imma need to find something like this soon, gonna install all four gsr disc brakes on my car...
in other words.... BUMP.
i have one at the shop i work at and you pump it to create pressure in the lines, just like pressing the pedals. mine just clamps to the master cylinder resivoir and then a line comes off that to a hamd pump
Re: one man brake bleeder kits (ohboy95c)
the directions said something about keep pumping it untill u see no air in the lines. so im guessing the line is long enough so that when there is only clear fluid with air bubbles and u let off the brake itll only suck back in fluid with no air. its kinda hard to explain.
Re: one man brake bleeder kits (tca0bell)
used the motiv one... (also following the write up on h-t that someone did that gives you a great seal on the top of the resevour.. dont ask me i forget who did the write up, do a search in the archive)
5 brake bleeds, works perfectly fine..
Re: one man brake bleeder kits (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">used the motiv one... (also following the write up on h-t that someone did that gives you a great seal on the top of the resevour.. dont ask me i forget who did the write up, do a search in the archive)
5 brake bleeds, works perfectly fine..</TD></TR></TABLE>
searched, cant find it.
funkfnamna
03-02-2005 08:44 PM
