LS into a 92 hatch
LS into a 92 hatch
Yo whats up guys, I recently bought an LS motor and I plan on doing the swap and I just wanted to know what I will be needing in order to make the swap work.. the wiring harness came with the motor...if that helps any.
Re: LS into a 92 hatch (Silspeg6)
I should pretty much drop in if you have all the mounts, linkage, axles, and harness. You may run into wiring issues if it is OBD2, but if OBD1 should drop in and bolt in pretty easily.
preetyboi06
07-17-2009 09:57 AM
