help with 95 civic cx..
Re: help with 95 civic cx.. (Serdar)
Doesn't crank over but you can push start it, eh? So it runs fine after you push start it? All accessories work (ruling out battery)? What happens when you try to start it? Clicking?
Check the connections at the starter first, then try replacing it. I'm not sure if AutoZone, etc. can test starters or not.
1 Post
Re: help with 95 civic cx.. (H22AEG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22AEG2 »</TD></TR><TR><TD CLASS="quote">starter solenoid</TD></TR></TABLE>
Which is, if you had any idea what you were talking about, one with the starter. Therefore must be replaced with the starter.
Obviously the only problem you are having is that the car will not crank. No other problems what so ever.
It needs a starter.
It needs a starter.
MinimalXistance
03-19-2006 10:56 AM
