ITR Sways on EG
ITR Sways on EG
Whats exactly required
i know u need
ITR Sways (but of which year?)
the end links?
LCa's for the rear?
thanks!
for my EG hatch
i know u need
the end links?
LCa's for the rear?
thanks!
for my EG hatch
Re: ITR Sways on EG (Mistermark)
for the rear:
1)ITR swaybar
2)ex/si rear LCAs (or gsr/ls/rs rear lca's also work) (type r lca also works but you must have a type-r style shock)
3)ITR endlinks (ex/si and gsr/ls/rs endlinks work also)
4)beaks kit at the minimum
5)ITR D bushings and D brackets
1)ITR swaybar
Re: ITR Sways on EG (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH »</TD></TR><TR><TD CLASS="quote">for the rear:
1)ITR swaybar
5)ITR D bushings and D brackets</TD></TR></TABLE>
Actually, the only rear LCA's you can use are the ones from a DC integra, del sol, or ex civic sedan. ex coupes and si's never came with a rear sway bar so they won't have the mounting points.
1)ITR swaybar
Re: ITR Sways on EG (RTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTI »</TD></TR><TR><TD CLASS="quote">Actually, the only rear LCA's you can use are the ones from a DC integra, del sol, or ex civic sedan. ex coupes and si's never came with a rear sway bar so they won't have the mounting points. </TD></TR></TABLE>
i dont think thats correct
The only EX and SI 94-95 that have rear sway are the one that are come with ABS.
Re: (Mistermark)
isnt there smaller sways??, *<22, i read somewhere that on an EG, it will damage the sub-frame, since its so think for the dinky car...info???
Re: (Mistermark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mistermark »</TD></TR><TR><TD CLASS="quote">thx for all the help
and what about the front sway?</TD></TR></TABLE>
Use 92-95 EX or SI that original have front sway or use 94-01 integra any model.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilPinkEye »</TD></TR><TR><TD CLASS="quote">isnt there smaller sways??, *<22, i read somewhere that on an EG, it will damage the sub-frame, since its so think for the dinky car...info???</TD></TR></TABLE>
Mostly happen on the 96-00 civic. If you are using 21 or lager sway i recommend you use ASR subframe reinforcement kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH »</TD></TR><TR><TD CLASS="quote">i dont think thats correct</TD></TR></TABLE>
What is correct then? If I am wrong I would like to know what is correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">The only EX and SI 94-95 that have rear sway are the one that are come with ABS.</TD></TR></TABLE>
Having abs doesn't mean the car will have the mounting points for the sway bar. The arms will look like the integra LCA because they have the mounting points for the ABS line. I have seen arms with ABS mounting points but the sway bar mounting point is not drilled or tapped. Besides the del sol and integra, only EX sedan came with a rear sway bar. No hatchs or coupes ever did, regardless of whether they had abs. Has anyone seen otherwise?
Re: (kaiba)
Mostly happen on the 96-00 civic. If you are using 21 or lager sway i recommend you use ASR subframe reinforcement kit. </TD></TR></TABLE>
Gracias
Gracias
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTI »</TD></TR><TR><TD CLASS="quote">What is correct then? If I am wrong I would like to know what is correct.
Having abs doesn't mean the car will have the mounting points for the sway bar. The arms will look like the integra LCA because they have the mounting points for the ABS line. I have seen arms with ABS mounting points but the sway bar mounting point is not drilled or tapped. Besides the del sol and integra, only EX sedan came with a rear sway bar. No hatchs or coupes ever did, regardless of whether they had abs. Has anyone seen otherwise? </TD></TR></TABLE>
I saw it on both hatch and coupe have abs with rear swaybar from the factory as stock.
Re: (Mistermark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mistermark »</TD></TR><TR><TD CLASS="quote">do the front require same stuff like LCAs?</TD></TR></TABLE>with the front you need the bar front lcas, brackets, endlinks and bolts. the front is harder than a 13-14mm rear install but easier than the 22-23mm rear install.
Re: ITR Sways on EG (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">I saw it on both hatch and coupe have abs with rear swaybar from the factory as stock.</TD></TR></TABLE>
Has anyone else seen this? I have a very hard time even finding a hatch or a coupe with ABS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTI »</TD></TR><TR><TD CLASS="quote">Has anyone else seen this? I have a very hard time even finding a hatch or a coupe with ABS.</TD></TR></TABLE>94 95 only right? i thought you were right but, i cant confirm it. neither answer would surprize me. i have seen it, however i thought that the person just put on a teg rear bar. sorry i am of no value...
better reinforce the subframe if youre going to put anything more than 14mm on there
I suggest asr over beaks..,Ive seens pictures of failed beaks, but not an asr
Re: (kaiba)
Good Info
Good Info
goldegg
09-26-2007 10:14 AM
topher
04-05-2002 08:09 AM
