HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE
The gayest stupidest thing happened.
I was performing a leakdown test and there is an adapter piece that screws in the hose, and that adapter screws in the spark plug whole.
I go to unscrew it all, and the hose unscrews from the adapter and the adapter stays screwed in. WTF
What could get it out???
UPDATE: got it out with 2 screwdrivers. Thanks to all for help.
Modified by drumminforev at 3:59 PM 2/1/2006
Re: HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE (delusionracer)
put 5 min epoxy on the hose and screw it in the adaptor.....................wait 5 min.........................unscrew
Re: HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE (solpower)
thanks for the idea, i knew some kind of bonding agent but wasnt sure what one to get for metal. either way, i managed to get 2 screwdrivers and clamp then around the sides and untwist....it was a bitch
Try putting the long part of the spark plug wire in there and try to turn in iam pretty sure that fitting is only hand tight let me kno if it works!
Re: (JDrock86)
lol, i did that before. You really have to make sure that adaptor on there is really tight on the hose. Luckly for me, it was not too tight and i found a socket that fit down the whole to get it out.
Re: HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE (saywhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat »</TD></TR><TR><TD CLASS="quote">I was going to suggest removing the valve cover.</TD></TR></TABLE>
the valve cover was off the whole time. it was deep still
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDrock86 »</TD></TR><TR><TD CLASS="quote">Try putting the long part of the spark plug wire in there and try to turn in iam pretty sure that fitting is only hand tight let me kno if it works!</TD></TR></TABLE>
i got it out with 2 screw drivers acting as a clamp. thanks for the advice all!
Re: HELP - STUPID ADAPTER STUCK IN SPARK PLUG HOLE (drumminforev)
well i know thread is done, but what i did was put sparkplug down into hole, screw it into the adaptor, and unscrew, ruined my sparkplug, but it got it out! put me into a tight spot, i was kicking myself in the a** after that one. lol
hmtcrxsir
10-16-2005 05:51 AM
vxnine
01-30-2005 01:46 PM
