MY cd player, cigarette lighter, and coin tray light have no power!
My cd player, my cigarette lighter, and my coin tray light dont work!!! i replaced the fuse under the dash a 100 times. so its not that. What else can it be and how can i fix it.Also i checked all the fuses and they all have power.
HELLLLLPPPPPPP!!!!!!
all the fuses are fine. The only thing missing is in the fuse box in the engine bay there is a thing missing. Its not a small fuse. It goes screwed into the fuse box. There is 5 of them im missing the third. Can that be it???
it should be a ground then. did you just install the radio? the reason i ask is that there should be a black wire behind your cig lighter panel. did you forget to put that back?
Re: (johnecon2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnecon2001 »</TD></TR><TR><TD CLASS="quote">The fuses under the dash are the ones you need to be looking at, not the ones under the hood.</TD></TR></TABLE>
Back up fuse under the hood would prevent the radio and clock from working.
Re: (BlueIntegraBoy)
and also the ecu so car wouldn't run. recheck the fuses under the dash read it find radio fuse pull it out with the pliers supplied and see if the little metal filiment inside is burnt or broken in two.. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Back up fuse under the hood would prevent the radio and clock from working.</TD></TR></TABLE>
You have a blown fuse UNDER THE DASH most definitly, if not. Then you have a world of headache instore backtracking wires looking for a burnt end/loose connection ;/ Goodluck.
its definately not under the dash! IT could be under the hood.(i hope) It also could be a burnt wire or disconnected wire. Ima figure it out today.
