Emissions Help!
Emissions Help!
update: All it needed to pass was a new air filter
Went for test today and failed.....
Now why would I fail when they do a test while simulated driving but not on idle?
Also what part could be the leading cause.
Thanks
Stock D16y7 engine with just intake
everything else stock
Modified by tony at 5:05 PM 2/2/2006
Thanks
Re: Emissions Help! (eXcelonTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eXcelonTypeR »</TD></TR><TR><TD CLASS="quote">Try a new cat. I burnt my cat out like 3 months after having it. Too much fun with the b16 lol</TD></TR></TABLE>
Prob too much fuel in addition to fun..
Re: Emissions Help! (JeffBro)
we need to see the numbers of the test, then we can see what might be the problem. scan or just post up all the numbers of the test
*edit* the pic was not showing up for me, but its up now
* B A N N E D *
1 Post
Re: Emissions Help! (Drew95eg)
Try seafoaming it, oil change, and have them check your 02 sensor. If none of them, have them check your cat. Your running rich, that means too much unburnt fuel. What kind of plugs did you put in, did u put em in wrong? are you running OEM wires? is your dizzy ok?
Splangtastic
06-19-2003 01:30 PM
