transmission problem..help please
ok let me tell you my problem and please try to help me
my shifter has been acting up sometimes the isnt and play in nuetral u know when its in the middle of the shifter you can move it left and right etc.
and 4th gear is like you got to actully put pressure on it when you shift to 4th and 3rd and 2nd grinds sometimes and goin from 4th to 5th i got to put pressure to get it in to the gear. and sometimes i cant even get it into a gear i gotta keep wiggling it until i can get it loose again and it then goes into gear
whats going on with it.. please help me
Re: transmission problem..help please (Arawn_Wilsawn)
sounds like syncro's to me. drop your trans. atake the case aprt and look inside or drain your trans fluid. put a magnet in the fluid see how much metal flake is in it some is normal alot is bad. and look for brass in the fluid alot of that means youve been grinding on the dogbones.
sportinjected
07-09-2008 08:21 PM
