Tranny makes noise...
anyone one know whats wrong with my car.. i have a b16 tranny. when i step on the clutch i hear this scratching noise.. it sounds like a whirring noise like dry leaves getting crushed. it also makes the noise when engage first gear.. when im in second to 5th gear is fine i don't hear the noise. It sounds worst and the sound is gets louder when i reverse... anyone know what this could be?
Re: Tranny makes noise... (em1 Ziggy)
yes when im depressing i just need some info before i get it to shop so they won't add extra stuff to the diagnose in other words i don't wanna get ripped off anyone know what this could be before i get it checked...
Re: Tranny makes noise... (schlit)
could be one or maybe more of three bearing.... the throw out bearing (the one on the release fork that actually contacts the pressure plate to release the clutch) The pilot bearing (in the flywheel, but doesn’t make since in this case because it would be heard all the time.) or maybe the main input shaft bearing (this one is actually inside the tranny... the bearing closest to the clutch housing and is known to go bad, however once again it would be heard most of the time. esp. in neutral no matter if the clutch is, or is not engaged....) hopefully this could be some help.
david
11-07-2005 09:24 AM
Emshhh
11
02-02-2005 11:10 PM
