Is the S4C tranny really a B16B(CTR) tranny?
Re: Is the S4C tranny really a B16B(CTR) tranny? (Hybrid93Eg)
Well since the b16b is a destroked ITR block I would assume that the tranny is the same LSD equipped one as the ITR.
Re: Is the S4C tranny really a B16B(CTR) tranny? (MotorMouth)
they are the same as the 00-01 civic si tranny
same gearing but with lsd
http://www.ff-squad.com/tech/temp/Bgears.htm
Re: Is the S4C tranny really a B16B(CTR) tranny? (vtec25)
As far as I know it's called the Y80 transmission. Only difference between the two are the fact that the Y80 should have a stock LSD on it.
The gear ratios are the same, as is the final ratio between the Y80 and S4C.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
I had a CTR tranny on my old setup. It was clearly labeled as an "S4C".. </TD></TR></TABLE>
Then you didn't have a CTR tranny, you had either a USDM B16A2 transmission, B16A3 transmission, a JDM SiR2, or a JDM SiR2 transmission with an LSD.
But as far as I'm concerned, who cares? They all have the same ratios.
well all i know mine has very short gear ratio cuz i be cruising in 4th gear at around 3800rpm's or so at 40mph or so.
could my tach be off?
Modified by vtec25 at 2:39 AM 3/17/2006
Re: (bsixteen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMouth »</TD></TR><TR><TD CLASS="quote">Well since the b16b is a destroked ITR block I would assume that the tranny is the same LSD equipped one as the ITR.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">What does this have to do with anything? He asked if the S4C was a CTR tranny. Not if the B16B was a destroked ITR motor (common knowledge)... Or if the LSD was any different then that of the ITR tranny. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTI »</TD></TR><TR><TD CLASS="quote">The S4C is not a CTR transmission. The CTR transmission is the same as 97 and older JDM ITR's and all USDM ITR's. </TD></TR></TABLE>
Well Mr. hybrid93eg, the b16b is the ctr motor and since that motor is a destroked Itr motor, and the 99-00 si tranny and usdm itr's share common gear ratios. Honda didn't make another tranny for the ctr they used an itr tranny. Which is what I was saying in the first post.
Waassa matta may englis not gud enuff fo joo to ndastand?
Re: (MotorMouth)
the 98+ spec jdm ITR's have the same first 3 gears as 96-97 jdm itr/99-00 usdm si/97-01 ctr/94-95 del sol, but has different 4 and 5 gears and a shorter final drive ratio.
Re: (MotorMouth)
Waassa matta may englis not gud enuff fo joo to ndastand?</TD></TR></TABLE>
I know what a B16B is you fool. I also know that its simply a destroked ITR motor, only there is a little more to it then just that. I just fail to see why you felt the need to start blabbing about "the CTR motor is this... " and crap like that.
9900, b16b, ctr, differential, fit, itr, motor, ratio, s4c, specs, starter, tranmission, tranny, transmission, y80
