VSS problem Need help!
Ok well i have a 94 civic dx, was auto and i converted to 5 speed and a gsr swap.
Now the problem im having is the speedo doesnt work anymore. I have changed the vss number of times. When i rev the motor the speed with jump and but wont move when the car is moving unless i go past 4,500 rpm and it will just jump all the was around to 0. Any help would be great, thanks.
Re: VSS problem Need help! (Civicb1894)
you have a loose/bad connection
check the plug side of the TPS sometimes switching sensors back and forth the rubber gaskets can get stuck in the plug (harness side) and cause a bad connection.
