Speed limiter
Re: Speed limiter (uncontrolled515)
if you get your ecu chipped and you use a program like uberdata you can disable the speed limiter.
Modified by tallyturbo at 2:15 PM 3/12/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo »</TD></TR><TR><TD CLASS="quote">if you get your ecu chipped and you use a program like uberdat you can disable the speed limiter.</TD></TR></TABLE>
Or crome,
Or crome,
Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo »</TD></TR><TR><TD CLASS="quote">if you get your ecu chipped <U>and you use a program like </U>uberdata you can disable the speed limiter.
you know uberdata, crome, hondata and all those good programs.
Re: (tallyturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo »</TD></TR><TR><TD CLASS="quote">you know uberdata, crome, hondata and all those good programs.</TD></TR></TABLE>
I was just concuring that you're right and giving the obligatory shout out to crome.
arg, there's g2 be another way around it, I don't want to chip it because I don't want it to run rich and act all gay, I've had too much exp w/ things running rich/lean and ******* with the car, I hate it, and I usually can never fix it, and since there's no dynos around here, I mean, I WOULD do it myself, but then I risk f8king up a 120 buck ECU, and nobody chips it reasonably, want like 70 bucks for 15 minutes of labor + 10 bucks in parts
not to mention I don't even think it's worth it w/o anything on it (only I/E), i mean ****, my next step would be to pull my old laptop out and make a RT tuner...but on a stock? c'mon....
