cleaning air intake filter
Hi,
I have a short ram air intake installed on my civic, but I don't know which brand it is. I got the intake from my bro who took it off a civic he recently bought. I don't really know how many miles the filter has been through. I put it on my car last november and probably put around 3-5k miles on it. I wanted to clean the air filter, but how should I clean the filter? Are there products I can buy, or are there household products that I can use to clean the filter.
Re: cleaning air intake filter (sp0097)
What kind of filter is it?? If it looks like a K&N, use the cleaner and oil that you can get at your local auto parts. If its stainless steel, soap and water will help clean it up.
Re: cleaning air intake filter (slammedeg693)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedeg693 »</TD></TR><TR><TD CLASS="quote">you cant clean a filter you just have to buy a new one, they never work the same after you try to clean them
Wrong. Some you can't clean some you can. K&N makes some filters you can clean
Re: cleaning air intake filter (teknoracing)
The filter itself looks like a K&N type (cone shape), I don't know what the material is (some kind of fibrous material), but the filter is not stainless steel. I will check out the stuff at the local shops, but can I use soap and water for the filter, I described above?
Location: Your mommas bed, that might be true too ..., So Cali, USA
thats what i did on my aem filter it works fine as new, just dont soak it where the filter material gets all loose cause then it most likely will fall apart
Re: cleaning air intake filter (Evolution-93-Ex)
If it's a k&n you can buy the cleaning kit for about $10 - comes with soap and oil. If you wash it, it needs the oil on it afterwards to filter properly. Wash from the inside out.
kcari
Honda Civic (2001 - 2005)
10
08-06-2007 08:38 AM
noltofan69
01-01-2006 03:24 PM
