FLUIDYNE RADIATOR problem
Old 03-11-2006, 06:12 PM
nek9's Avatar
Default FLUIDYNE RADIATOR problem
i just instaled my FLUIDYNE RADIATOR and conected all the hose, but for some reason smoke keeps coming out? i spilled some rad. fluid so i thought thats the reason it was smoking, so I jus let it run for 20 min. thinking that the spilled fluid would burn out. but it keept on smoking. so my question is should i keep on running the car to check if it would stop or not?
Modified by nek9 at 4:26 AM 3/12/2006
Old 03-11-2006, 07:27 PM
nek9's Avatar
Default Re: FLUIDYNE RADIATOR problem (nek9)
bump
Old 03-11-2006, 07:29 PM
DelSolMarine's Avatar
50/50 water coolant? are u loosing fluid or is it staying in there?
Old 03-11-2006, 07:32 PM
nek9's Avatar
Default Re: FLUIDYNE RADIATOR problem (DelSolMarine)
i use the 50/50 preston.. and the colant is staying in there.
Old 03-11-2006, 07:46 PM
thermostat opening? hum... and the temp gauge isnt moving up to hotter?
Old 03-11-2006, 07:52 PM
Global Moderator
tech8's Avatar
Let the car cool down. Then check the hose connections and clamps again, and the radiator cap. Then pour a little water and wipe down some of the areas where coolant spilled before.
Then start the engine and check again.
nek9's Avatar
the gauge isnt getting hotter. it jus stays in the midle. im not sure if the thermostat is opening or not, but why wouldnt it open?
Old 03-11-2006, 07:53 PM
nek9's Avatar
and how do i check if its opening or not?
Old 03-11-2006, 08:00 PM
nek9's Avatar
Default Re: FLUIDYNE RADIATOR problem (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">Let the car cool down. Then check the hose connections and clamps again, and the radiator cap.</TD></TR></TABLE>
so ur saying check for leaks.
Old 03-11-2006, 08:02 PM
did u flush the old radiator before u put the new one in? getting the coolant out of the motor 2? its either u have 2 much coolant 2 little or u just need to let it run through the motor more
Global Moderator
tech8's Avatar
Yes. Usually any steam is from a leak, or fluid spill.
Old 03-11-2006, 08:07 PM
Unceasing Measure
Archidictus's Avatar
Is the smoke coming from the exhaust or the radiator itself? Be more specific: are there multiple points of smoking? Does the smoke smell sweet like coolant or is it burning water vapor or oil?
Help us help you.
Old 03-11-2006, 08:21 PM
nek9's Avatar
Default Re: FLUIDYNE RADIATOR problem (Archidictus)
the smoke is from the radiator it self.. its coming from the mesh part. if u know wat i mean..the smoke is mostly in the mesh part of the radiator it it smells like burning coolant. i dont realy know how sweet coolant can semll like and or water vapor smells like, but i do know its not oil smell.
Old 03-11-2006, 08:30 PM
r u just letting it idle or are u driving it... id drive it and let the wind blow some of that coolant off.....
Old 03-11-2006, 08:31 PM
nek9's Avatar
i was jus leting it idle because i didnt want to in danger my motor..
Old 03-11-2006, 08:37 PM
erasable180's Avatar
you should probably drive it, its probably spilled coolant, i normally pour windsheild washer fluid over the radiator after i do a hose and/or bleed the system. then drive it. i wouldnt pour anything over it while its still hot though. also did your fan kick on?
Old 03-11-2006, 11:09 PM
nek9's Avatar
Default Re: (erasable180)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erasable180 &raquo;</TD></TR><TR><TD CLASS="quote"> also did your fan kick on?</TD></TR></TABLE>
no it did not..does anyone else have any idea
Old 03-12-2006, 04:37 AM
el_toro_de_magnifico's Avatar
Default Re: (nek9)
how long is it in idle? drive the catr for 20-30 min the check again. there might be a leak from the radiator itself.
Old 03-16-2006, 06:25 AM
Default Re: (el_toro_de_magnifico)
is the water temp gauge going up? just watch that when ur driving if it starts rising up just kill the ignition... stay near home when your doing it i had this issue with my B18C swap and it came out to be (not knowing) that the D16 radiator that i had in there had to small of radiator inlets... lol yea i feel dumb...
ShotnVA777
01-09-2014 04:13 AM
iHEARTMYCiViC
01-19-2010 04:53 PM
smokerz212
01-08-2007 05:13 PM
FastAssCars
09-06-2006 07:19 PM
satintegra
07-11-2002 10:37 PM
Quick Reply: FLUIDYNE RADIATOR problem
