swapping a d16y8 into a cx
well im taking out my b16 swap next week and putting in a d16y8 obd2.....juss wondering what i would need to convert the swap into an obd1....any help would be appreciated..
Re: swapping a d16y8 into a cx (civicb16eg)
What....Why??? Are you selling it or something????
Just of the top of my head...Your gonna need an OBD1 dizzy, OBD2 to OBD1 conversion harness
Technical Hero
I am assuming you have a EG OBD1 civic according to your screen name correct? You will need to swap the Y8 dizzy plugs over to the OBD1 plug if they're different and if you are using the Y8 injectors you will need to swap out the plugs for the OBD2's to use its injectors or just use some injectors from an OBD1 vehicle. Also the alternator plug is different so you will need an OBD1 alternator or I have seen some people swap over the plug in portion from an OBD1 alternator to an OBD2 alternator. You will also need to relocate the Intake Air Temperature sensor to the intake arm because the Y8 manifold doesn't have a spot for it. I guess you could use the P28 ECU for the swap to run it.
civicracer94
09-12-2007 12:16 AM
haroldthefly91crx
09-13-2006 04:35 PM
