does a 97" civic stock motor have a FITV?
I have a problem with the idle going up and down 1000-2500rpm. I search for a 97 civic stock motor but no results. Already replaced the IAC valve (#2 in diagram), still no luck. does it have a Fast Idle Valve?
Re: does a 97" civic stock motor have a FITV? (hatchback1997)
sounds like a simple vacuum problem, i have no clue wich vac line but test a couple make sure there not clogged, also check ur TPS, u can find the correct voltages for it on honda-tech somewhere... hope this helps
borrego805
02-14-2015 04:28 PM
happy123
05-21-2009 03:11 PM
