help!! need a tip
help!! need a tip
ok i just put on a coupe bumper on my 93 sedan, also got the aftermarket jdm lights , installed them into the bumper, everything is cool..now..
im doing the wiring, mounted the relay, ran the power into the battery, then grounded the ground wire, connected the 2nd harness to the power by banana plug, fished the wires inside the car, the red wire went right into the fog lights switch, now im left with 2 wires - black which needs to be grounded ,and a yellow wire...where does the yellow one go? do i splice it into the acessory wire in my car or what do i do? please help me out!
here is some pix i took
Modified by crxsi777 at 8:53 PM 10/12/2006
Modified by crxsi777 at 8:54 PM 10/12/2006
Re: help!! need a tip (ricekiller1)
well there is once harness...that plugs into the fog lights switch
black wire - that gets grounded
there is a yellow wire - what do i do with that one?
doesnt it have a clip on the end of the wire? anyways i think that wire needs 12v ignition power ....there are spots to clip into ignition power at the top of your fuse box in the car...but you need the clip that fits...mine came with the clip
i got a 93 sedan....i guess for a coupe u can just plug it in, with myne its just the yellow wire adn i dont know where to tap it into acessory? or ignition...i mean..the red wire is ran from teh battery and it runs right into the fog light switch
