does check engine light mest up my performance?
Ek Forever y0!
Re: does check engine light mest up my performance? (nek9)
sure, if the gasket is blown or your o2 sensors aren't working.
Very vague question, The check engine light can range from sensors to you not having your gas cap tightened enough.
Re: does check engine light mest up my performance? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">sure, if the gasket is blown or your o2 sensors aren't working.
Very vague question, The check engine light can range from sensors to you not having your gas cap tightened enough.</TD></TR></TABLE>
i guess i didnt make the qestion specific. I was actually asking about the o2 sensor?
Ek Forever y0!
Then yes.
You should have asked about the o2 sensor. Your check engine light could be X amount of things.
Your o2 sensor will make a difference because it will alter your air/fuel ratio because your ecu isnt getting a correct reading.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Then yes.
Your o2 sensor will make a difference because it will alter your air/fuel ratio because your ecu isnt getting a correct reading.</TD></TR></TABLE>
tnx that really help
vxtirent08
03-22-2008 10:51 PM
JinDIESEL
09-17-2004 06:33 AM
